Water pump and odd sound
Old 03-03-2011, 07:47 AM
FastHackem's Avatar
FastHackem has much to be proud ofFastHackem has much to be proud ofFastHackem has much to be proud ofFastHackem has much to be proud ofFastHackem has much to be proud ofFastHackem has much to be proud ofFastHackem has much to be proud ofFastHackem has much to be proud ofFastHackem has much to be proud of
Well, I brought my 04 CS into Firestone to get a lifetime alignment and while it was in there they called to say that the water pump sounds like its going out. Now I have been hearing a sound that sounds like rocks grinding together under water ever since I bought the car from Carmax. I have read on the forums that a grinding sound from the engine area is typical though and have thought nothing of it until now. What do yall think? Normal? Or maybe I should take it over to the stealership and see what they think? I might try posting a video tonight.
Old 03-03-2011, 10:23 AM
TenaciousT's Avatar
TenaciousT is on a distinguished road
I don't know about grinding, but a ticking sound is normal. The water pump will usually trickle a bit before it goes. Any leakage?
Old 03-03-2011, 10:51 AM
ClutchnThrottle's Avatar
ClutchnThrottle is on a distinguished road
Yup. Your water pump is wearing out. I had the same sound coming from mine before I replaced it. I did not have any leaks before I started hearing the sound. It was fairly easy to replace. You can buy the part from either Suncoast or Sunset for around $135 IIRC. Good luck.
Old 03-10-2011, 09:56 AM
FastHackem's Avatar
update: Stealership confirmed dead water pump. Replaced under warranty.
turbotuner20v
09-11-2015 12:02 PM
LiquidElephant
08-27-2015 06:17 PM
OldBoldPilot
08-24-2015 04:00 PM
Quick Reply: Water pump and odd sound
