Indicator light problems
My 2004 Cayenne S started having some indicator light problems the other day.
On occasion, when indicating to turn left, the warning message pops up "check indictor light" and the arrow-shaped indicator on the dashboard starts blinking at a more rapid pace. When getting out of the car all of the actual indicator lights on the outside seem to be working properly. Then if I stop the engine and start it again, the warning is gone and the indicators seem to work fine.... until at some point the warning shows up again...
Anyone else having this problem? Any ideas of what causes this and possible fixes?
Thanks!
-J-
Thanks!
-J-
Just discovered my right front signal bulb was melting through and about to cause a fire. Well, eventually. It appears someone changed the bulb before I bought it and failed to seat it in all the way. Does this help?
Thanks!
-J-
Thanks!
-J-
Thanks!
-J-
Thanks!
-J-
Had similar experience over time. Then the front bumper was removed; they found an improperly seated right turn signal bulb was melting through the plastic and eventually would cause a fire. We replaced the melted housing for $20 and made sure to seat the bulb fully in the new housing.
Intermittent turning signal warning.
I had this problem on my 2006 Cayenne Turbo, right front turning light. Especially in cold sub-zero weather. The bulb change, holder contact clean-up, and torx screw tighten up as described previously worked for me. I had to do all three before I got consistent fix though. Thanks to posters for help.
LiquidElephant
08-27-2015 06:17 PM
GSR Autosport
08-26-2015 05:20 PM
