does anyone know the rolling diameter of the Porsche Cayenne?
I am looking to replace the factory with aftermarket 22s and wanted to see what is the rolling diameter of the 18s? Please advise.
Also per tirerack, thinking of 285-35-22s for tires.
http://www.tirerack.com/wheels/resul...rSpecial=false
is that advisable?
I am looking to run square set-up, not staggered.
any input would be appreciated.
thanks!
or would a 21 inch setup with 295-35-21 be a better solution.
This will be my wife's car primarily.
cost for 21 with tires and 22 with tires is about the same.
is that advisable?
thanks!
I am just going through the same situation myself
295 x 35 x 21 is a OEM standard size. I am heading in that direction as mine too is a shopping trolley for the wife and think it a better compromise on size
285/35/22 is probably the best size for 22's on the cayenne. There are a number of good choices for tire in that size too. You could do 295/30/22 or 265/35/22 also but there's less sidewall on the 295's and the 265's look small.
255/55.18 is standard,
285/35.22 was my choice,
the 295/30.22 is not ideal imo and YES makes the right size but the 285/35.22 is a better choice because of width, sidewall, and look.. and overall your barely off on the OD.
should we consider that not all tires brands have the same outside dimension/overall height?
per tire rack
295/30/22
Conti Cross Contact - 29"
Michellin Diamaris - 29"
Pirelli Assimetrico - 29.3"
285/25/22
BF Goodrich G Foce T/A - 29.9"
Kumho Ecsta SPT - 29.8"
Pirelli Assimetrico - 29.8"
Sumitomo HTR - 29.9"
Yokohama Parada - 30.1"
295/35/21
Dunlop SP - 29"
Pirelli P Zero - 29.1"
Yokohama Advan - 29"
Continental Cross Contact - 29.1"
per tire rack
295/30/22
285/25/22
295/35/21
Dunlop SP - 29"
FWIW, anything over 20" and you might be sorry; ride gets a little rough.
I'm looking at 285/40/20 which is identical circumference to stock. You can get the /45/ without any errors, but the speedo will read 2.2mph slower.
This may help you:
http://www.miata.net/garage/tirecalc.html
This may help you:
Rob,
By any chance did u have a white Lambo Countach and live in Ashburn area before?
As for sizes, i had 22s on my Cayenne S and it was not bad at all.
Also, have air ride which is suppose to make the ride a bit smoother.
I might go with 21s since it's wife's car.
Raja
Raja
LOL ~ Small world !
I had detailed your Masi but it was Abe who you lent to for Prom.
PM me your telephone number, i will call you.
Raja
albert@velosdesignwerks
Cayenne
08-28-2015 06:36 PM
Cayenne 958
08-19-2015 02:43 PM
