Overboost Code and Problems!! Help
Old 03-24-2011, 11:52 PM
aguita's Avatar
aguita is on a distinguished road
Im having this code and problem... heres the symptoms
When i go WOT the car push hard as always but after some more WOT runs it doesnt build any more boost,the exhaust sound changes drastically and it barely hits 0.4..
I have changed the Diverter valves back to stock without luck..
Im pointing to change the N75 valve (Boost control Solenoid)..
what could be the problem? thanks
Codes stored on ECU are
p0234 Overboost
Mods are
AGP DV Valves
GIAC Tune
Evolution Motorsports Filters
IPD Plenum
Fabspeed Exhaust With bypass pipes
FVD Intercoolers
If the problem is the Boost Solenoid Im Planning on upgrading to the AGP Boost Control Solenoid..
please Help
Old 03-25-2011, 05:34 AM
FastHackem's Avatar
FastHackem has much to be proud ofFastHackem has much to be proud ofFastHackem has much to be proud ofFastHackem has much to be proud ofFastHackem has much to be proud ofFastHackem has much to be proud ofFastHackem has much to be proud ofFastHackem has much to be proud ofFastHackem has much to be proud of
I would look toward the BCS also. You may be able to take it apart and clean it out. Do you ever have boost oscillations or inconsistant boost? Also look around the engine bay for any damaged or broken vacuum hoses. Im also concerned with your GIAC tune. Was it tailored to work with the extra parts you put on, plenum, intercoolers, etc? Sometimes when you put extra parts that the tune is not designed for on, the computer cannot compensate for the extra flow fast enough so an overboost situation can occur.
Old 03-25-2011, 07:07 AM
aguita's Avatar
thanks for the reply.. the tune was made for the mods I have.. Car was perfect till last week..Im putting 486 hp to the wheels, is there any way to clean the BCS?
Thing is I dont know why the problem starts after couple of WOT runs...
Old 03-25-2011, 07:37 AM
FastHackem's Avatar
Could be the turbo getting super hot. I drove a tuned GT2 and after a few runs the boost wouldnt come anywhere near peak. There were no CELs though. My BCS on my WRX was able to be pulled apart and cleaned. On the Cayenne I am not sure whether or not it can be taken apart. I bet though at least you could just shoot non-chlorinated brake cleaner through the ports when its energized and not energized by taking some leads and hooking it up to the battery jumper post.
Old 06-12-2011, 05:57 PM
Did you find the cause of this?
Old 05-10-2019, 10:05 AM
Zuffenhausen955's Avatar
Zuffenhausen955 will become famous soon enoughZuffenhausen955 will become famous soon enough
Agree, GIAC tune is an overly-aggressive, generic mapping that is notorious for heat-soaking many turbo vehicles....
Old 08-09-2020, 05:02 PM
Tecchie's Avatar
Tecchie is an unknown quantity at this point
Would the BCS (at rear of engine, yes?) cause boost surging also? Mine sometimes sits at 0.4 bar, other times starting from first gear from dead stop, I can feel it surge with lots of power.. I get the same code. Stock otherwise.
Old 08-16-2020, 10:19 PM
Bigbuzuki's Avatar
Bigbuzuki will become famous soon enough
Opening of the turbo waste gates is controlled by pressure in the lines to the wastegates.
Over boost can be caused by leaking / split wastegate lines or wastegate actuator diaphragms as either wastegate may not be opening when required, thereby putting the system in an over boost situation.
Old 08-19-2020, 09:31 PM
Tecchie's Avatar
Waste gate, what would cause it to not get full boost unless I do a slow roll?
Or if I'm cruising on the highway and hold it in 4th gear for several seconds, then downshift to 3rd under full throttle, I get full boost and LOTS of power.. Thoughts? 125k miles and everything is stock/original except wear parts.
Old 08-21-2020, 07:13 PM
Bigbuzuki's Avatar
If the ECU senses an overboost condition and latches the overboost code, it will then limit the boost to a maximum of 0.4 bar until reset.
magoochi
11-21-2015 10:50 AM
powder
11-19-2015 07:44 AM
levinsje
05-09-2015 04:39 PM
bmwtmx
01-23-2014 11:31 AM
TURBO ELECTRO
11-06-2008 03:58 PM
Quick Reply: Overboost Code and Problems!! Help
