Windshield wipers revisited
Hi all,
I know the wipers have been covered quite a bit but I seem to have a slightly different issue causing a similar problem.....
In my case the drivers wiper leaves an un-wiped streak in the center of the blade on the upstroke. The passengers blade leaves an un- wiped area in the lower area regardless of blade direction.
Here is what I found: On the passenger wiper arm there are two 16mm nuts holding the arm on. The right one is loose. When I torque this nut down both the drivers and passengers blades work perfectly! No elephant sounds either by the way........ The problem is the nut loosens as soon as I use the wipers and we are back to square one......
Just wondering if anyone has seen this on their Cayenne, and did replacing the two nuts and washers resolve the issue??
PS I have tried blue loctite so far with no success.....
Bob
Bob
Bmw M3 Guy
02-21-2018 09:29 AM
speedsterr
10-26-2015 09:18 AM
