05 CTT 45kmiles VS. 06 CTT-S 100kmiles which one should I get?
Old 05-29-2011, 08:07 AM
zzzx's Avatar
zzzx is on a distinguished road
Question 05 CTT 45kmiles VS. 06 CTT-S 100kmiles which one should I get?
found these two
05 CTT 45kmiles
06 CTT-S 100kmiles
about same price
I know CTT-S has bigger brakes, front and rear tires are different and different ECU, more hp
this will be my DD car in snowy winter, and most likely in the city, will not track. I DO plan to get snow tires.
any input will be appreciated.
Old 05-29-2011, 08:14 AM
cuemaster's Avatar
cuemaster Is a GOD !cuemaster Is a GOD !cuemaster Is a GOD !cuemaster Is a GOD !cuemaster Is a GOD !cuemaster Is a GOD !cuemaster Is a GOD !cuemaster Is a GOD !cuemaster Is a GOD !cuemaster Is a GOD !cuemaster Is a GOD !
the 05, but i wouldnt worry about miles, these things are built to last
unlike every american car that turns to junk at 100k. mine has 104k on it and is perfect.
Old 05-29-2011, 10:37 AM
Markenstein3D's Avatar
Markenstein3D is on a distinguished road
CTT-S has more power, but with the mileage, i'd take the 05 CTT, then upgrade ECU (GIAC, EVOMs, Upsolute - see Cole's thread).. make sure the plastic coolant pipes are replaced with the aluminum pipes, check service history, etc.
Old 05-29-2011, 12:58 PM
zzzx's Avatar
thanks guys.
in terms of driving experience, whats the difference between these two trucks?
Old 05-29-2011, 01:41 PM
when i was looking for my cayenne, i test drove the CTT and the CTT-S.. the CTT-S pushed me back a bit than the CTT. I didn't know (at that time) that it had bigger breaks, but I know it's more HP and bigger inter-coolers... but with bigger breaks comes bigger bucks in terms of maintenance ;-)
Old 05-29-2011, 08:03 PM
zzzx's Avatar
i guess so and from some pictures it seems that the rotors are two-piece ones.
Old 05-30-2011, 09:19 AM
make sure though that it's a real CTT-S.. i've seen a lot of CTT that are 'rebadged' as CTT-S.. the door sills, body kits and other stuff can be installed in a CTT to make it 'appear' as like a CTT-S... unless you have them side-by-side then the brakes are obvious. as said, inter-coolers are bigger + powerkit to bump the power up.. i assume these are the big difference in terms of the CTT and the CTT-S (for the 955's).
Old 05-30-2011, 09:20 AM
get the VIN and check with porsche.. i know there's a post here in the forum somewhere that decodes the VIN and will show you all the options in the cayenne.
Old 05-30-2011, 09:57 AM
Bigbuzuki's Avatar
Bigbuzuki will become famous soon enough
Old 05-30-2011, 10:45 AM
imcarnuts's Avatar
imcarnuts Is a GOD !imcarnuts Is a GOD !imcarnuts Is a GOD !imcarnuts Is a GOD !imcarnuts Is a GOD !imcarnuts Is a GOD !imcarnuts Is a GOD !imcarnuts Is a GOD !imcarnuts Is a GOD !imcarnuts Is a GOD !imcarnuts Is a GOD !
I know these are built for lots of miles but there is still a huge difference between 45k & 100k miles. I would go for the 45k miles. Just my opinion. Brakes are great on the non s and you can always do the ecu if you think you need more hp.
From Car & Driver. "Surprisingly, we had to squint to see the performance improvements. The Turbo S shot to 60 mph in 4.9 seconds and whizzed by the quarter-mile in 13.5 at 107 mph, just 0.1 second quicker to 60 mph and no quicker through the quarter than the Turbo."
All of the extra hp in the S does not come into play until the time at which most reasonable people have stopped accelerating. Again from C&D "The extra horsepower is apparent at higher speeds, as the Turbo S was 5.7 seconds quicker to 140 mph and topped out at 166 mph versus 161."
Old 05-30-2011, 11:04 AM
taddyangle's Avatar
taddyangle is on a distinguished road
Given the price is similar, I would go with lower mileage. If you decide to sell in 3-5 years, it would be easier sell an 05 with 85k miles vs an 06 with 140k miles.
Old 05-30-2011, 02:26 PM
cordsig79's Avatar
cordsig79 has a spectacular aura aboutcordsig79 has a spectacular aura about
05 hands down, mileage is king.
Old 05-30-2011, 08:03 PM
zzzx's Avatar
wow thanks guys for all the input
1,Mark3D, i did not know that someone could actually rebadge the car into a similar model. thanks for the heads up. so the VIN will actually say that it is an CTT-S?
2, the website that Mr.Bigbuzuki provided is super cool, it gives the option details!
3, Mr.Carnuts, I guess the high end hp does not make sense to me at all if i never going to track the truck.
4, and Taddy, it is true that with lower miles it will sell faster.
thanks again guys.
4,
Old 05-30-2011, 08:41 PM
Dennis C's Avatar
I'd check for maintenance records and get a PPI also. Just because a car has lower mileage doesn't mean it's a better car. All things being equal, from a maintenance and PPI standpoint, I'd go for the 2005.
Old 05-31-2011, 06:41 AM
zzzx's Avatar
True I'd prefer it is runing regularly rather than sitting in the garage all the time.
some of the cars are already modified. In this case, should I avoid them at all or any perticular spots that I should be careful with?
thanks
Quick Reply: 05 CTT 45kmiles VS. 06 CTT-S 100kmiles which one should I get?
