WTF: ABS failure workshop warning! SUV won't start.
Old 12-10-2011, 10:37 PM
PORSCHEFREAK's Avatar
PORSCHEFREAK has a spectacular aura aboutPORSCHEFREAK has a spectacular aura aboutPORSCHEFREAK has a spectacular aura about
I go to start the suv and it makes a funny noise, wont start and I get a lovely warning being displayed. ABS Failure Workshop. Any others ever have this issue? If so could you share your experience.
Old 12-11-2011, 10:48 AM
Jace's Avatar
Jace is a glorious beacon of lightJace is a glorious beacon of lightJace is a glorious beacon of lightJace is a glorious beacon of lightJace is a glorious beacon of lightJace is a glorious beacon of light
Anything to do with the battery going dead? Maybe it sent a false reading since the charge went low?
Just a thought.
If its true to the warning, I've never experienced.
Old 12-11-2011, 11:50 AM
Cole's Avatar
Cole is just really niceCole is just really niceCole is just really niceCole is just really nice
There is a vacuum line that cracks on the passenger fender that often causes this error code. Wrap some electrical tape around it and it usually cures it.
I would imagine if it cusses enough of a leak the computer might shut down the car when you try to start it.
Old 12-11-2011, 07:09 PM
Bigbuzuki's Avatar
Bigbuzuki will become famous soon enough
I had the cracked vacuum line and it displayed the red Brake Booster Faulty warning message. The vacuum line went to the vacuum pump for the brake booster. Vacuum pumps are only on the Turbos IIRC.
Old 12-11-2011, 09:25 PM
Problem solved. Tow truck guy came and started the suv Apparently there could have been air in the gas tank or the suv was flooded... Whatever the case it works now so all is good.
Old 12-12-2011, 04:16 PM
cordsig79's Avatar
cordsig79 has a spectacular aura aboutcordsig79 has a spectacular aura about
I had a vacuum line failure near the engine.....it caused low oil pressure signal and high revs on my 6er.....
Was still getting bad faults on ABS and cat/02 sensors as well.
you should still go measure the cold cranking amps of the battery......if below 700-600, your going to need a new one shortly. Mine was reading 255, yikes...
Batteries Plus/Autozone or Orellys
PV=nRT.
09-09-2022 06:06 PM
pwdrhound
09-13-2016 10:44 AM
BLKMGK
05-31-2016 04:32 AM
carsnob
09-08-2015 04:10 PM
katyrow
09-07-2015 10:17 AM
Quick Reply: WTF: ABS failure workshop warning! SUV won't start.
