957 - HID/Bi-Xenon - Headlight Blackout w/ Lens Mod [PICS]
One of the more popular bulbs, which is the same ones that I am using, is the OSRAM Xenarc 5000K Cool Blue Intense HID bulbs. They make a D1S and D2S variant. The model for the D1S is: 66144.
Thanks! - Much appreciated.
Update:
Even though the light output is much improved, I think I might be slightly out of focus, so I ordered the ZKW-R lenses to swap out the STi-R lenses. They should be here by the beginning of next week.
I also received my OSRAM D2S Xenarc 5000K Cool Blue Intense HID bulbs. I have to use them for about 6 hours for them to "warm up" to 5000K. I will post up pics soon after I perform the lens swap and put some hours on the bulbs- looks promising!
yeah I think the zkw will do you some good especially to help bring the cutoff into focus. You could always measure the thickness of your stock lenses with a caliper if you have one (taken at the max) to compare between zkw and sti
you'll love the CBI bulbs when all broken in too.
Lastly, X5X...the 955 actually comes stock with bixenon valeo D1S projectors from the factory, so if yours isn't giving you a high beam mode, something is broken. If both lights aren't going into high, perhaps check your fuse box for a blown high beam fuse. I can consult you on various options for the headlight overhaul, shoot me an email direct to matt@theretrofitsource.com
Very nice job! If the CTT were my daily, this is how it would look like.
Are the stock lenses easily switchable or would you have to bake/pry open the headlights? Also, which cornering light bulbs did you go with to match your HID bulbs?
By the way, I am having a hard time adjusting the manual vertical height of my passenger headlight. It is pointing about 6 inches lower than the driver side. I know for a fact that it was this way before I started my project, where it looks like someone else was tampering with the adjustments before I got my hands on it. I plan on looking at it when I swap out the lenses for a manual fix - hopefully it is not broken. Any suggestions?
Keep in mind that these projectors work in conjunction with the air suspension and have a good degree of motor movement.
You can view Cole's thread for the original information:
https://www.6speedonline.com/forums/...dlights-3.html
Cool! Thanks. If I wasn't modding, I think I would get bored. Running out of reasonable mods now
Have you blacken the window trim and panel? Stock is silver painted. black trim suits better with your porsche exclusive style ctt
Update:
I just re-opened up the headlights and swapped out the 22mm STi-R for the 27mm ZKW-R lens. Not fun to do it twice since I had to pull out all the tricks when prepping to make sure it stays completely dry. I also able to manually recalibrate my passenger projector to match the driver projector height, so I should be 100% good to go as soon as the glue finishes drying.
Here are a few pics of the ZKW-R lens:
27mm ZKW-R lens
Wow.. that is crystal clear!
..so clear in fact that I can read the imprint on the cutoff flap!
I will post up some night pics as soon as the HID bulbs fully break in.
27mm ZKW-R lens
wow that does look good.
So how does the output compare? did you fire them up before resealing the lenses? There are always other little tweaks and things that can be done to enhance the light output, such as spacing the frame that holds the lens forward from the body of the projector, etc.
There is an entire "underground" to the automotive aftermarket JUST dedicated to projector optics and tweaking headlights, believe me!
Curious to see the difference between the STi-R and ZKW-R on those Hella projectors, which seem like an updated version of their "bread and butter" E55 model.
I did do a little research over on HIDplanet and saw several people tweaking their Hella projectors with washers to dial it in, just a smidgen more. On these "updated" versions of the Hella, the D2S base/reflector is riveted to the lens holder assembly . So there is no way to "space out" the lens farther away from the bulb- without completely removing the assembly and drilling/grinding off the rivets and using machine screws and nuts. Considering the complexity of these projectors, it did not seem worth the risk of damaging anything. Maybe someone else will be more bold.
I will post up final pics soon. Stay tuned guys.
Sorry for the delay guys, we have had consistent precipitation in the NE for the last few days. As soon as the rain goes away, I will take/post the final shots.
It looks very promising. The misses has been very impressed with the lighting improvement over stock as well. The light output is very uniform and easy on the eyes at night.
The silver lining is that I have over 300 rain-soaked miles and my headlights are dry as a whistle inside - zero leakage. So glad all the extra prep work on the second resealing paid off!
