Lowering Modules
#61
FWIW, member "SLVR-GTstreet" was able to take my Durametic instructions and reprogram his level control module using a PIWIS while visiting his tuner. So the steps, are probably not too far off.
Different interfaces - Yes. However, I was fairly certain it is the same physical level control module. Meaning that the part numbers will cross reference in the PET and ETKA programs. Probably not too surprising when you consider that the VAG group uses the the air suspension technology across Audi, Porsche, VW and Bentley. I have the tech articles from Porsche that I can find if you are interested.
#64
For those who were interested, I've put some pressure on the powers that be, and got the go-ahead to lower the price of our lowering control unit by over 20%!! Hopefully this helps some people who were undecided because of price...
http://www.championmotorsport.com/pr...cmslcu955t.htm
#65
tom - is this price still there? where does this module go & presume easy to do?
finally, i assume you will ship across the ditch to Canada
#66
This unit installs in line with the factory control unit, which on most models is located in the trunk area.
Shipping to Canada is not a problem.
#68
Actually, the price you are seeing is our "new" retail price. The unit used to cost $1400, but in response to a pretty strong demand for lower pricing, we lowered it to $1100.
so instructions are included Tom & simple DIY
#69
Some experience with simple wiring would be helpful. If you've ever installed a basic car stereo then this should be simple for you.
#70
ok Tom - out for a week so will call in a bit. thx -
#71
no problem. You can even just order directly from our website (link above). All those orders get processed by me anyway.
#72
i read somewhere onanother thread? that you must get a new alginment if you plan on driving it in reduced height mode most of the time - never seen that comment before but person sounded like they new what they were saying?
#73
It is recommended. I never got an alignment after lowering and have been fairly happy with the evenness of my tire wear. On my second set now. However, your experience may vary due to any number of factors.
#75
As far as alignment...anytime you lower a vehicle it is always recomended to do an alignment because your changing the complete setup of the suspension of the vehicle. Its up to you if you want to do that...can you get away without it? of course.
