Tutorial: How to lower your Cayenne Air Suspension w/ only a Durametric [DIY]
#46
here is another question for renn~man...
Can we or have you tried to lower even more than the 25mm just added? Like maybe another 15mm?
I may try this but wanted to know the implications before attempting.
For example, is there a point at which the suspension will be affected (so low, that range of function will be affected, etc)?
I know the car will be lower, but want to make sure that the shocks to not get into a situation where they adversely affect the car handling. Thanks.
#47
Once you lower it with the durametric if you go back into the system it will show the same values that were originally there before you lowered it so if you try to go down farther you only enter in how much farther you want to go. So if you already lowered it 25 and want to get to 40 total youd only put in the number shown plus 15. If you try to put in 40 itll give you errors learned that the hard way.
EDIT:
I'm attempting this for the second time and can't get Channel 1 (FL) to learn a new value. It errors every time while Channel 2,3 and 4 learn just fine.
Any ideas why Channel one (FL) errors and won't learn? (I've tried everything to get it to learn numerous times.
#48
Great point! I learned the hard way with this too. I was confused cause everytime I went back into the program it shows the same values.
EDIT:
EDIT:
#53
Hahahaha...
Cool - glad that you were able to get it lowered. This is the way the air suspension should have been from the factory in my opinion.
#54
I agree 100%, not only for the stance, but I love the way it rides as well
#55
Anybody close by to Toronto, Canada that I can go to and help me with this as I dont have durametic.... I called both local porsche dealers but they refused to touch it with this approach..... I am willing to pay....
#56
If you cannot find anyone, I still have my original tuned module that I am willing to part with. Send me a PM if you are interested.
#57
Good point for those with means to help. Only the pro version will give unlimited vin work. Others have mX number of vins they can use their cables on. I am sure there has to be more than one cayenne in TO area. Maybe Canadian porsche forums?
#58
I posted on the Rennlist forum in Canada but no response..... anybody in buffalo,ny or chicago/new york (business trip's next several weeks) that can help? I am willing to drive
#59
OK so I finally found a local garage with a Durametric that is willing to do it. Can you please advise the levels each wheel should be? (150mm?) I would like to lower it as much as possible without effectng the ride comfort. Also, I have 20' Turbo Rims on my car. Also, do any error or fault messages come up using this meethod of lowering it? Thanks for all your time and help.
#60
If I were you, I would do the distances as shown in the DIY article on first page. That gives you a decent lowering already. I think in this thread I posted some pics of before and after, so you can compare. You will have to do no more than the listed amounts each time when you add to the numbers in the software or you will be getting errors. If you want lowering more than the max then you will have to do the process twice, adding the next interval you want, but as said, I would do no more than the originally said measurement.
