CTTS '06 not making power?
#46
That's not bad at all. I'm concerned with the silver oil. I would pull the airbox on that side and see if you can disconnect the intake pipe that holds the MAF from the turbo inlet. There is a black plastic adapter that angles @ a 45 and it connects to the compressor housing with two allen screws. I think you could get to that and remove it. Then you would be able to see the compressor impeller and housing. You should be able to grab the shaft with your fingers and check for play or any evidence of rubbing.
I guess its possible that you could have enough shaft play and when it started it just shaved the housing and gets worse, but never enough to totally hang up. There's only so many places the silver flakes could be from. It's gotta be the compressor rubbing the housing.
#48
I agree with Mr. Haney those numbers look good since you are within 10% deviation between all cylinder compression numbers.
I would also consider taking his advice to try to check the play in the turbocharger housing, however, space is very limited in that area.
Given the options, I would:
1) Perform a leakdown test to confirm that your engine is good:
2) Remove the oil filter and cut it open to verify more metal deposits.
3) Potentially trying to get hands on the turbo compressor wheel
If these hold true, then all signs are pointing to a bad turbocharger.
#50
that's not bad at all. I'm concerned with the silver oil. I guess its possible that you could have enough shaft play and when it started it just shaved the housing and gets worse, but never enough to totally hang up. There's only so many places the silver flakes could be from. It's gotta be the compressor rubbing the housing.
i agree with mr. Haney those numbers look good since you are within 10% deviation between all cylinder compression numbers.
Given the options, i would:
1) perform a leakdown test to confirm that your engine is good:
2) remove the oil filter and cut it open to verify more metal deposits.
3) potentially trying to get hands on the turbo compressor wheel
2. I've already done an oil change and cut the filter open for inspection. Thankfully, i found things to look normal.
3. I did try this and didn't notice any play, but the silvery oil has to be from the turbo...
Thank you guys for all the input, I really do appreciate it
#51
Vig03,
I know you did not find a smoking gun, but I think you gathered enough evidence to reasonably assume your turbos are going bad. Either drive them until they seize/blow-a-seal or change them out now. Not sure if I am leaving out any other options.
#52
I definitely don't feel comfortable with the turbo and wouldn't want to risk any further damage to my internals. I actually feel very lucky that my compression results are reasonable. I do plan to do a turbo swap, but I want to get a couple more data logs to see if there are any other issues outside of the turbo that may be contributing to my symptoms of low power. Once I have some logs I'll post them up. Thanks
#54
I was looking at some of the parameters for data logging with a Durametric last night. I found "Air mass sensor left" and "Air mass sensor right". I plan to data log with these parameters and see if there's a difference. Assuming that my passenger side turbo is good, a lower reading on the left MAF may help validate the bad turbo. Maybe I can compare logs to another member to see if one or both are not functioning properly. I guess I'd also be assuming my MAFs are both in good shape...
#55
These are the best option I have found for a direct bolt in performance replacement,
http://www.hybridturbos.com/hybrid-t...turbochargers/
#56
Thanks Mr. Haney. I'll probably just end up having mine rebuilt by Midwest.
Unfortunately, I'm still trying to figure what else could be contributing to my problem; I'm convinced there is more to this. I did another set of data logs and it seems a bit off. My ignition angle seems to be all over the place and total Air Mass is still odd. Also, I did all runs WOT in 3rd gear only from 2k-7k RPM.
I'm really confused by all this. Maybe RM can chime in?
#58
I'm taking a look at a possible boost leak again. My data logs for Air pressure just don't make sense. Will hopefully have some more info soon...
#59
I am on my mobile device now, so I am limited. Give me a few hours to get to a computer and I will see what I can make of the info here...
turbotuner20v
09-11-2015 12:02 PM
Fabspeed Motorsport
Audi
08-21-2015 11:30 AM
