Secondary air injection pumps
Old 04-19-2014, 10:04 PM
ciaka's Avatar
Anyone know if the secondary air injection pump on pass side is same as the pump on the driver side?
I took out the driver and looked at pass, and think they are same, but wanted to see if anyone knows for sure.
Took apart the bank 2 (driver) and the fans were destroyed. Need another one for sure.
Old 04-20-2014, 04:41 AM
Bigbuzuki's Avatar
Bigbuzuki will become famous soon enough
The 2 pumps are different.
For cylinders 1-4, part number is 955 605 104 21.
For cylinders 5-8, part number is 955 605 105 11.
Check the associated downstream valve that each air pump feeds.
They fail open and exhaust air goes up the pipe to the air pump and destroys the blades. Recommend you change the valves whilst your there.
Valve part number for both sides is 948 113 203 51. This is applicable for a 955 turbo.
Old 04-21-2014, 11:10 PM
Mr. Haney's Avatar
Mr. Haney is a splendid one to beholdMr. Haney is a splendid one to beholdMr. Haney is a splendid one to beholdMr. Haney is a splendid one to beholdMr. Haney is a splendid one to beholdMr. Haney is a splendid one to beholdMr. Haney is a splendid one to beholdMr. Haney is a splendid one to behold
The real culprit here is the foam that the air pumps use to filter the incoming air. With age the Foam gets dry-rott and disintegrates into the fan blades packing them full. They tend to not live long after that. Otherwise its a fairly robust motor that gets used infrequently by the ecm. You should be able to disconnect the rubber pipe at the air pump and use your mouth to blow into the valve. Its a one way check valve that should let you blow air in but not suck it back out. You can remove those valves and clean them out, they aren't cheap.
Old 04-23-2014, 12:17 PM
ciaka's Avatar
Good help... I was going to ask about them. Saw prices and new replacement is about $120-160 each.
Will def try to remove and clean
BTW, have you tried removing it? Anything special to do that?
Thanks.
Old 04-26-2014, 05:27 PM
Mr. Haney's Avatar
Im not sure about removal on the car. They are in a crappy area. I do know it is two bolts from the bottom, located on either end of the coolant crossover tube, behind each cylinder head.
Old 04-30-2014, 08:08 PM
ciaka's Avatar
Well, I guess I will find out.
Ordered a new secondary air pump and will take a peek at the valve before install.
Maybe, if I really feel like it, I will take some pics to make a decent DIY for this.
We'll see.
Old 05-02-2014, 08:08 AM
Mr. Haney's Avatar
What would be great is if you could find the actuating pressure on the new one so as to compare the value against what used valves require. I blew into mine with my mouth and it took quite a bit of pressure to make them open. It's hard to imagine the air pumps deliver that much pressure...maybe my valves are tired?
Old 05-02-2014, 11:35 AM
spooltime's Avatar
spooltime is a jewel in the roughspooltime is a jewel in the roughspooltime is a jewel in the roughspooltime is a jewel in the rough
All of your other DIYs have been way more than "decent." No doubt this one will be equally superb!
Old 05-05-2014, 05:20 PM
ciaka's Avatar
How did you clean the valves out?
I ser a lot of carbon residue on outer part of valve. I blew out the pipe and sure enough, there was old foam material that was in it that came out.
Can you spray with carb cleaner to clean?
Also, wha t about the foam. I am inclined to install without any foam.
Your thoughts?
Thanks.
...You can remove those valves and clean them out, they aren't cheap.
Old 05-11-2014, 01:48 AM
ciaka's Avatar
just to wrap this thread up, I did the replace of the pumps, and the cleaning of the hose and valve. Created a DIY thread, so find it on this forum if you need to do this job with additional info. Good luck.
Old 05-14-2014, 09:36 PM
ciaka's Avatar
OK. I was driving today and the CEL came back on again. My first thought? CHIT!!!
What could it be?
Came home, pulled out the laptop with Durametric. Code? P0492.
Same secondary air injection pump - bank 2 (driver side).
I replaced the pump (with OEM brand new one).
Removed the valve and the hose. Blew out any debris in it and cleaned out the valve (it is a manual valve with one piece lifting up to allow air through, once enough force has built up).
So with the new pump, cleaned out valve and hose, I should not have any more issues.
However, the CEL returned for same bank, so there must be something going on.
Disconnected hose and connected again, as well as disconnected wire plug, cleaned with electrical contact cleaner, blew out to dry and reconnected. Will see if helps but I doubt it.
Could it be a fuse? Is there a fuse for injection pumps?
Any ideas on testing to isolate for issue? What can be done with Durametric to help here?
Appreciate any input here.
Old 05-15-2014, 04:41 AM
spooltime's Avatar
The attached file is the diagnosis procedure from the factory DME manual which includes electrical values to test for. Only steps for Bank 1 are in the manual; steps for Bank 2 are the same. Hope this helps.
Old 05-15-2014, 10:56 AM
ciaka's Avatar
Think I got it figured out.
Located fuse in manual for secondary air pumps.
They are located in engine compartment (next to brake fluid reservoir).
Open the lid, and look for:
Fuse 3 - sec. air pump bank 1 (pass side)
Fuse 4 - sec. air pump bank 2 (driver side)
Mine was bank 2 (driver). Pulled out and seemed OK until I looked very closely and observed black residue on inside of plastic cover.
Checked with ohmmeter and confirmed lack of continuity. Fuse blown.
Checked fuse 3 and confirmed it is OK with Ohmmeter (near zero resistance).
So now I will have to hunt down a 40A fuse for this sucker to confirm the final fix.
Moral of the story - check your fuse too.
Old 05-15-2014, 04:40 PM
ciaka's Avatar
...replaced fuse with another 40A fuse, from advance auto parts ($5.19).
Will observe for more CEL occurrences. Will post up later again.
Thanks.
danyoP4S
09-30-2021 05:06 AM
Rguy
04-12-2020 11:11 PM
rzmnco
Cayenne 955/957
05-07-2016 09:06 PM
Rockinc1
09-30-2015 06:44 PM
shifter_
09-08-2015 12:07 PM
Quick Reply: Secondary air injection pumps
