Leistung Bypass = Fail
I have had the same issue happen with the hangers breaking on both of my bypass pipes from them and have had them welded twice, still breaking. I contacted them about the issue and they said they would send me out new pipes with the new design, but it has been over 2 months and no sign of the pipes showing up and no response from them after multiple attempts to contact them. I am upset with their products and customer service.
I sent Hanksville an email to see what they're willing to do about it. It will be interesting to see if I get a reply.
The re-welding idea seems reasonable, except i) it shouldn't be necessary; and ii) changes are very likely it will just crack again since the bracket rod is far too brittle for the application.
Given that, what are anyones' experiences with the other bypass pipe vendors like FVD and Fabspeed, to name a few? I know Fabspeed had problems with their hanger's clearances; has that been fixed now?
Fvd
I have fvd and so far everything is good but there exhaust hangers or hanger is to long and hits the frame so you have to cut it down a bit. I think paying all this money for some simple pipes you think they would be perfect. Other then that I'm happy with the sound and quality
Okay, I'm adding Hanksville to my preferred vendor list.
I contacted them about the cracked hangers on my Leistung pipes and they have indicated they will send me a replacement set to swap in exchange for the defective ones. This is awesome customer service, given that they don't really have any responsibility for the shoddy Leistung parts since they're a separate company. I don't even mind that I'll have to do another R&R and then ship the duds back to them. I assume they can use the returned parts to install proper hangers on. I'll post more details when the replacements arrive.
PelicanParts.com
09-25-2015 03:17 PM
