Bypass install fitment issues suggestions?
#61
Will do. I will be taking it back in approx. 2 weeks to swap out the supersport exhaust for the SR-1 just for comparison sake and so Hank has sounds/video of both systems on a car.
#63
Cool, I'll be interested to hear the SR-1 as well. I already had downpipes so that's the only HHR product I'm not running, but they still exit in a 3".
#65
He has gotten a lot of requests for tips....he discussed the possibility of adding something tip-wise to the line up given the demand and lack of good options.
#67
I don't, I went with Fabspeed because they were a huge improvement over stock, plus my last muffler shop welded my stock turbo tips to the pipes, thus rendering them not easily re-useable, The fabspeeds are only 2.5" but they are a very nice 2.5", given no choke points, but one of the best things for at the time was that they were in stock and in hand in 3 days
#69
Has anyone ever done the bypass and said it's just too loud for an SUV and put the cats back on? I'm looking for a better sound but not something loud or raspy. Maybe a little less than a mustang GT stock.
#71
What's in the picture is considered an H-pipe. I'm pretty sure porsche was not looking at max performance also when they designed the exhaust, more like max noise reduction. The exhaust I am having fabed is a full 3" system from turbos to tips and what I am after is max performance not DB levels.
#72
X-pipe: Mid-pipes built with a crossover, or "X" shaped design, purposely cross exhaust streams to even out flow and streamline exhaust gasses through the rest of the system. X-pipes are generally raspier and louder than H or Y-pipes and have been shown to provide slightly more power than their counterparts. You are likely to see most of the power gains higher in the rpm band with an X-pipe.
http://www.americanmuscle.com/mustan...s-x-pipes.html
#73
I took mine off and put cats back on....was way too raspy for my liking. I have dual Magnaflows too though. Sounds much much better with cats on. I may try the resonated ones eventually.
