Bypass install fitment issues suggestions?
Purchased some bypass pipes from Hanks and am having some fitment issues. After install I noticed a loud rattle upon acceleration. I checked the install and noticed the drivers side pipe rubbing against the crossmember (about 1mm clearance). I tried prying up on the pipe and adjusting the hanger but no luck!
Called Hank and he offered a refund or suggested I put some washers under the crossmember but I am not sure that is ok since the trans support bolts to it and I dont want to throw anything else out of alignment.
I am also getting an exhaust leak at the rear connection. Is their any sort of sealant I can use?
Welcome to the club. My Hanksville driver side bypass doesn't fit either. Hank says he has a 955 coming into his shop in a few weeks and will adjust his welding jig then and send a replacement. In the meantime, the rattle is so bad and so frequent that I'm going to reinstall the secondary cats temporarily because it's just ridiculous to spend hundreds of dollars on some really simple piping and not have it fit or have it break (Leistung). I know, at least, the factory pieces fit correctly.
From your pictures, yours has the identical clearance issue that mine does. It simply bends inward too soon towards the rear, causing it to bump into the cross member. I would strongly advise against putting washers in and attempting to adjust the cross member downward in that fashion. It's a not a fix for a poorly designed and manufactured part. I'm hoping he steps up as he said he would and fixes the design of the part and sends out a replacement. We'll see.
And to keep the rant going, is there a single bypass vendor that actually supplies a set of secondary cat bypass pipe that actually fits and is durable? Every single vendor I'm aware of has had an issue - Fabspeed with the hangers binding into the chassis, FVD with the support brackets being too long and needing trimming of length, Leistung with brackets breaking (and delayed or non-delivery), Hanksville simply not fitting, and B&B not fitting as well (see above). These pipes aren't rocket science, and it shouldn't be so hard to find a quality aftermarket part. But it is. Very sad.
And to keep the rant going, is there a single bypass vendor that actually supplies a set of secondary cat bypass pipe that actually fits and is durable? Every single vendor I'm aware of has had an issue - Fabspeed with the hangers binding into the chassis, FVD with the support brackets being too long and needing trimming of length, Leistung with brackets breaking (and delayed or non-delivery), Hanksville simply not fitting. These pipes aren't rocket science, and it shouldn't be so hard to find a quality aftermarket part. But it is. Very sad.
I think I am going to have to remove the pipe and make a huge indentation where it is rubbing with a hammer. This is the only way I think I can fix the problem for the time being. I would put back the stock pipes but they where so rusted I pretty much destroyed them. This is complete BS having to deal with this.
I am assuming Hank got some sh*ty jigs from Leistung. Hopefully he steps up and gets out pipes that fit to his customers ASAP! I dont have weeks to wait on this as my wife is about to kill me!
Any suggestion on the rear section leaking?
This thread sucks as I just ordered a set of primary and secondary car deletes from Hank. I really can't have these kind of issues as the truck is in Costa Rica and shipping is expensive and time consuming. I really hope he sends me a set that clear the cross member. Is the issue due to the 3" diameter or just the way the pipes are bent?
If you wrap that section of the pipe that goes over the cross member with heat wrap that would solve the "rattle" you are hearing. It's still needs to be addressed by the manufacturer and the problem needs to be fixed.
Do your hangers all fit? If not you may have them in on the wrong side. Mine were mis-marked and I had to swap them. If both hangers line up on both sides though that may not be your issue. I am going to get mine up this weekend to take some pics but mine fit better than all these pics.
Do you have pics of the driver side, right above the cross brace? I want to compare if possible?
Looking back in my email and the instructions I got for installing mine it says that clearance will vary due to variations in how much the flex hose on the end of the downpipe sags. But it also says there should be 3/4" clear and I don't think I have that much room. I will get it up tomorrow and check things out. There has to be a simple way to fix this.
As I said I wrote Hank an email to let him know my concerns about the fitment and this was his response.
Hi, Brian. Thanks for the message. Just yesterday I heard about a second fitment issue on our secondaries. One 955 Turbo that I had previously heard about, and now a 957 Turbo, both rattling on the crossmember. All of our pipes are made on the same jigs, so if the issue is with two out of dozens of pipes shipped since June, then I think the issue might be with fabrication inconsistencies. However, if there are more instances that I don't know about then the issue might be with the jigs.
We obtained the jigs from LMS and have wanted an opportunity to install parts on an actual car, to verify the accuracy of the jigs.
Clearance on your pipes is even more critical with the 3" tube.
I will have a car in the shop next week beginning on Oct. 6; that will allow me to check fitment on all of our parts and also to perform R&D on our 3" midpipe. We have already fabricated your secondary but I will plan to wait t o send it until I can get that car in next week, to verify fitment.
Quality and customer service are my priorities. During the week of Oct. 6 I am diagnosing and making new pipes for the customers who advised me of their fitment issues, and will make sure that yours fit correctly before they ship. I'll keep you posted.
If you are on the forums, please feel free to share this message and please ask if anyone else has issues. I am available via phone or email ( info@hanksvillehotrods.com ) and welcome feedback and pictures to help me to fix the issues. I'll also add this to my blog on www.hhrproducts.com. Thanks.
Hank
Hanksville Hot Rods, inc.
303.470.1850
At the end of the day this is the type of vendor I want to do Buissness with.
Hank
303.470.1850
