955 CTT cutting out on light throttle
Hi guys
Seem to have developed a new issue. On light acceleration, I feel a miss/cut out of sorts. Sometimes it cuts off fully almost and comes back. Sort it like a fuel cut
Sent it to the dealer and they couldn't find anything wrong. They said it may have been bad fuel. But I've been having it for a while now
Any suggestions on what to look
This problem isn't there when I floor it.
I have just hit 40k km on the clock
Update
The vehicle developed a really bad set of misses finally where the abs light and the light next to it (triangle with the arrow round it) came on
Turned it off and started again and it seems fine
Desler says to change the pumps (fuel filters were changed last month)
Has anyone experienced this ? I feel if it was the pump it should happen all the time including full throttle
Any ideas on what it could be
I've heard about the dreaded slow or hard start issue because of the fuel pumps or pressure regulator.
Here are a few threads on that topic. May be a similar issue?? Could also be MAF's or coils.
https://www.6speedonline.com/forums/...rm-solved.html
https://www.6speedonline.com/forums/...r-feeling.html
https://www.6speedonline.com/forums/...g-neutral.html
https://www.6speedonline.com/forums/...eleration.html
I've been having a loss of power issue. Took it to the dealer they found nothing. Took it to an indy and they took the car for a drive with the computer hooked up and noticed one of the primary cats isnt working right. Not under warranty anymore so i must just gut them.
I would get a can of dedicated MAF cleaner and start by cleaning the MAF sensors. Replace your plugs with new ones and make sure they are gapped correctly. You can use good ol regular ngk platinums and they work just as well as the beru's for like 4$ each. Coils could be suspect to. They provide more than just a spark and are responsible for dwell and saturation too. Light throttle tip in is still closed loop operation of the ecu and all sensor information will be taken into acct to provide the best performance.
Fuel, air, spark. It's a process of elimination. Start covering the basics before you throw money and parts at the problem .
LiquidElephant
08-27-2015 06:17 PM
GSR Autosport
08-26-2015 05:20 PM
PelicanParts.com
08-26-2015 04:25 PM
PelicanParts.com
08-26-2015 04:24 PM
