2008 Cayenne Turbo excessive crankcase vacuum
I just bought the car from a dealer earlier this month (no warranty/my loss **** happens) with 55,000 miles on it.
The car drove fine for the first couple hundred miles then I got a misfire code for cylinder 8 I pulled the plug and it was fouled bad other spark plugs looked fine, did a compression check on all the cylinders everything it within spec. I checked the Air-Oil separator and the diaphragm seemed fine. Kinda stumped right now.
Any help/ideas would be greatly appreciated.
Worst comes to worse if anyone knows of any good shops in the Baltimore, MD area would be great.
Sucking oil into intake
I thought my diaphragm was ok too until further and much closer inspection. It had a hairline split that was barely noticeable. Lifted off manifold cover and intake valves were a horror story of sludge. I bought the car like this, unfortunately. Discovered 4 valves weren't seating. Cleaned intake valves as best I could. Installed a $14 oil can separator and within 2 weeks 2 valves re-seated themselves. The suction is crazy on these engines, but that's why they are so powerful.
socialpro
Cayenne 958
05-18-2016 09:58 AM
PelicanParts.com
08-20-2015 03:00 PM
PelicanParts.com
Cayenne 958 Vendor Classifieds
08-20-2015 02:59 PM
PelicanParts.com
08-20-2015 02:57 PM
Yotam Refael
Cayenne
08-18-2015 03:03 PM
