CTT hesitation at WOT question
If one is experiencing hesitation at WOT (feeling like car starts sputtering a bit when throttle pressed hard, lasting for few seconds), does it usually mean check plugs and coils? What is there aren't any engine codes stating of any misfires?
I have felt this and have no codes pointing to plugs/coils. I know from doing valve cover gasket change that several of my coils have cracks in them.
Wondering if that should be first place to start or look more to fuel pumps. Kind of thinking replace plugs/coils first. What say you? Thanks.
Kinda what I thought. Now of to find what best plugs to get. Already planing to get the latest Beru coils they have for the car.
The coil number I have is 94860210421.
Close to $32 price/ each - hope it's a good deal. I assume that's all I would need- the coils and plugs (no gaskets involved in this swap).
Also can anyone clarify to me on warranty for already replaced coils by dealer? I had coils replaced by dealer about 50-60K ago, by dealer themselves.
I thought I came across something saying if my plugs were originally replaced by dealer, if they crack again, they would be covered to be replaced again by that dealer.
Could that be true?
Thanks again.
Could that be true?
Thanks again.
It could be true, you'd want to check with the dealer. I'd at least give them a call before I jumped into it myself.
I think thats not a bad deal for the coils, been a while since I priced a set. I don't remember needing any gaskets for the coils and plugs.
Going back to shop timorrow to check it out
Funny thing is that this is happening in sbjmper to bumper traffic
If I clear the code and run it hard no issues
as an update, after I replaced coils and plugs, the thing is running like new. Better. The hesitation was due to plugs worn and coils cracked (did not bother finding out which - replaced both - plugs visibly in need of change, coils cracked - all but one, so all went).
Thank you for all help.
Josh/AWE
VW
12-04-2015 03:36 PM
Josh/AWE
12-04-2015 01:30 PM
