Four wheel drive system faulty
I have a 2006 Cayenne S. Over the last couple of months I've been getting the "Four wheel drive system faulty" message popping up randomly while driving. When I shut the car off and restart it generally goes away only to came back at a later time. The 4 wheel drive system still appears to be working fine as far as I can tell and the car drives without any issues.
I remember reading something a while back about possibly some transmission sensor going bad. Supposedly it's a quick and easy swap. Can anyone shed any light on this regarding the fix and the parts (part #s) involved? Thanks in advance.
[url=https://flic.kr/p/PdRsCt]
Not enough voltage IMO. BTDT.
There are many crappy batteries out there including Interstate sometimes that have a short life. Cayenne's have a lot of electric gadgets that consume power.
My original Verta slowly fading but I keep topping off with distilled and put it on the CTek charger every now & then.
When the light is OFF... shift the CS in neutral and toggle Low Range several times. It just needs to be "used" occasionally. When not used - the electrical contacts corrode slightly, which triggers the "4-wheel drive system faulty" message, whenever a voltage drop is detected.
sounds interesting - I think I will try this.
Battery - when my car is cold and the battery isn't charged well (short trips with the car) it lights up when I start the car. Also it really started happening when I upgraded the nav to a double din unit. I turn off the car and start it up again and the light goes off.
