How To Replace Parking Lights Inside Headlights
These are the ones that come on inside the headlight with one click of the headlight toggle switch. I've had everything apart under the hood but no luck. Does the headlight have to come out?
Yes, the entire headlight unit comes out. It only requires a few turns from a special tool in the tool kit. Its pretty simple once you know how to do it.
I changes the same lights took about 15 min with the tool kit from the trunk. the entire headlight comes out, but it is something really easy to do, not as complicated as I though it would be.
BUT....
be very careful when removing the headlamp there is a tray underneath it with a fin like assembly on it...dont break it costly fix!!
haha
i would know had to have both lenses redone by dealer 185.00 per lamp
haha
04-28-2022 12:38 AM
PelicanParts.com
08-21-2015 01:37 PM
