40K Mile Service?
Old 05-24-2007, 08:10 PM
SoCal955's Avatar
SoCal955 is on a distinguished road
40K Mile Service?
How much have you guys paid for the 40K mile service? My dealer quoted me $1,100. Has anyone gone with an independent shop or done it yourselves? I think he said it included spark plugs, oil change, pollen filter, air filter(not sure on this one), and battery maintenance.
Old 05-25-2007, 06:57 PM
SoCal955's Avatar
Has anyone done the 40K mile service on a V6?
Old 05-27-2007, 08:42 AM
alirob's Avatar
alirob will become famous soon enoughalirob will become famous soon enough
The 40K mile service on my 04 CS was $376.79. This included new wipers and new pollen filter. The CS maintenance manual calls for new plugs at 60K miles not at 40K.
Old 05-27-2007, 08:56 AM
porschespeeddemon's Avatar
porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !
If it is a turbo or V6, it includes plugs at 40. also 2 air filters if turbo, and check the ignition coils.
Old 06-11-2007, 02:08 PM
SoCal955's Avatar
So, is it safe to say no one has reached 40k miles in a V6?
Old 06-11-2007, 10:32 PM
GoldenPEPPA's Avatar
GoldenPEPPA is on a distinguished road
socal stealers are a joke.
Old 06-11-2007, 10:34 PM
SoCal955's Avatar
What did you pay?
Old 06-12-2007, 12:57 AM
lol... I'm at 23k, they wanted $650 for the 20k, Which was an oil change and a cabin filter plus the usual checkup stuff. I did the oil change myself and saved $300.
Old 06-12-2007, 01:23 AM
SoCal955's Avatar
Do you know whats all included in the 40 K mile service? I listed what I think is included in the first post, do you know any different?
Old 06-12-2007, 01:44 AM
turbo187's Avatar
turbo187 Is a GOD !turbo187 Is a GOD !turbo187 Is a GOD !turbo187 Is a GOD !turbo187 Is a GOD !turbo187 Is a GOD !turbo187 Is a GOD !turbo187 Is a GOD !turbo187 Is a GOD !turbo187 Is a GOD !turbo187 Is a GOD !
Minor maintenance after: 40,000, 80,000, 120,000, 160,000 miles etc. (60,000, 120,000, 180,000, 240,000 km etc.)
-Diagnosis system: Read out fault memory
-Vehicle underside and engine compartment: Visual inspection for leaks (oils and fluids) and abrasion (lines and hoses)
Underbody panels: visual inspection for completeness, installation and damage
-Change engine oil and filter
-Particle filter: replace filter element
-Check drive belt
-Steering gear: visual inspection of bellows for damage; tie rod end: check the play and dust bellows
-Power steering: Check the fluid level and bellows
-Fuel lines and connections: visual inspection
-Coolant hoses: Check condition; radiators and air inlets at front: visual inspection for external contamination and blockage; Coolant: check the level and antifreeze protection
-Foot-operated parking brake: check free play
-Brake system: visual inspection of the brake pads and brake discs for wear
-Brake hoses and lines: Visual inspection for damage, routing and corrosion. Checking the brake fluid level
-Drive shafts: Perform a visual inspection of the boots for leaks and damage
-Front cardan shaft: visual inspection of rolling lobes for damage (up to '03 model)
-Rear cardan shaft: visual inspection of centre bearing for damage (up to '03 model)
-Axle joints: check the play and visually inspect the dust bellows for damage
-Exhaust system: visual inspection for leaks and damage, check suspension
-Tires and spare wheel: Check the condition and the tire pressure
-Lubricate door latch snib and fastening pins
-Windscreen wiper/washer system, headlight washer: Check fluid level and nozzle settings, pay attention to antifreeze protection in the winter months; check wiper blades
-Seat belts: check operation and condition
-Vehicle lighting: Check function; All headlights: Check adjustment; Horn: Check operation.
-Battery and vent hose: check condition
-Electrical equipment as well as warning and indicator lights: Check operation.
-Trailer hitch: check operation
-Airbag system: check operation and condition (see Additional Maintenance)
-Test drive:
Remote control, front seats, foot and parking brakes (also actuation travel), engine, clutch, steering, transmission, ParkAssist, automatic speed control, heating, air-conditioning system and instruments: Check operation.
-Oils, fluids: visual inspection for leaks
Old 06-12-2007, 09:49 PM
SoCal955's Avatar
Thanks for the thourough information!!
Old 06-13-2007, 01:04 AM
turbo187's Avatar
no problem. just took a copy and paste job
Old 06-03-2008, 05:29 PM
Vyper340's Avatar
Vyper340 has a spectacular aura aboutVyper340 has a spectacular aura aboutVyper340 has a spectacular aura about
Is the Cardan Shaft covered on a CPO??
Old 06-04-2008, 11:35 AM
EMart's Avatar
EMart is on a distinguished road
It was for me.
Apex Chase
03-28-2016 02:00 PM
SharkyShark20
09-19-2015 09:54 PM
gulf gt
08-27-2015 10:27 AM
Vrseis
08-20-2015 07:41 AM
Quick Reply: 40K Mile Service?
