Resetting Oil Change Indicator
#61
Glad to learn about the iCarScan. Curious if and how you able to update the info each year as new models come out and codes are added/corrected? Wish it was available when I sprung for the Durametric (later returned as the codes were not accurate) but meanwhile my $45 X-431R has done the job well. Noticed the iCarScan doesn't have Tesla but not sure there is any data available out of that port although one exists.
#62
Another vote for icarsoft POR II i960 (different than their older unit without oil reset), it turned out to be everything I had hoped in a tool and I can easily reset the oil and service reminders when I perform them myself. I had troubles with the durametric and their tech support tried but never got the unit to reset the oil, I have used the icarsoft the last 3 times with zero problems.
It looks like it will clear the other two service reminders as well, once their time comes. For $160 shipped Amazon Prime, it was/is well worth the money. This is the deal right here:
#63
Originally Posted by BenCD
I bought the same iCarsoft POR II 960 and it cleared/reset the oil change light/reminder easily.
