Changing the engine air filters on 958 Cayenne - DIY w/ pics
Very easy and cheap DIY for the air filters on a 958 Cayenne Turbo.
These filters are pretty universal between various Cayenne models and VW Touareg, regardless of engine size (V8, turbo or diesel).
IIRC, i spent around 30 bucks for two filters.
Start to finish time took no more than 30-minutes.
Remove the small additional cover (top portion for coolant access) on passenger's side.
Passenger's side: Remove the plastic 'push pins' in order to remove the side cover. This provides access to the air filter box.
Driver's side: Remove the plastic 'push pins' in order to remove the side cover. There is approximately 4 per side. This provides access to the filter box.
Removal of the plastic housing on either side requires removal of the 'push pins'. Use a small flathead or knife to pop the middle section up...then lift the entire 'pin'
Passenger's side air filter box after side panel removal.
Driver's side air filter box after panel removal
The above plastic screws/bolts only need to be pulled straight up. While there is a slot/key at the bottom, i didn't have to use any tools to turn and align. This allows you to disconnect the tubing from air filter box. Once disconnected, you will be able to lift the air filter box to allow access to the filter.
A close up of the hole slot and end of plastic 'bolt'
Gently pull the plastic tubing out from the air box then lift the air filter box straight up to access the filter.
Air filter element is pretty obvious once air filter box is lifted up and out.
One year old filter left....new replacement on right.
Filter specs and cross reference for various brands
Thanks gnat.
That's actually a good question.
I'm not sure which Cayenne model take two filters and which takes one.
I could guess, but that would provide little to no value here!
Huh. Just got on the computer so I could give you the rep you deserve and noticed the bit about the bolts and disconnecting the pipe. I did mine on the diesel without removing that pipe, though being able to remove it and that half of the housing would have made the job less of a hassle. Will need to remember to look for those next time.
My filter was a bit over 2 years old with 20k and looked about the same. Now the cabin filter, that was really nasty!
Great job and explanation Blazin!!
Speaking of cabin filter, my interior started smelling bad almost like vinegar with maybe 15K miles and I brought it to Porsche to replace it. Problem solved! Would definitely like to do it myself next time! (Hi Gnat!)
I don't see anyway i could have done it without moving those bolts and disconnecting the pipe.
There just was no room to slide the cover back or up.
I was relieved how easy it was to simply pull the bolts up and out.
I said i wouldn't guess, but i suspected that the V8's had two filters.
In that light, I noticed that the GTS was not included in your list.
Two filters there too?
Whoops - must be all these exhaust fumes getting to my brain - yes, the GTS does indeed take 2x filters as well!
So that begs the question in the 958.2 (2015) GTS:
As a 6 cylinder now.....one filter or two on the twin turbo?
I know, i know....beyond the scope of this DIY.
Just curious now
Just curious now
Different chassis - but the Macan S and Macan Turbo we've done here for basic maintenance all took two filters. Both V6 Turbos
I would assume that the V6 diesel block is smaller than the V8 which would give me a bit more room than you had
