DIY - 958 PCM3.1 Video Interface and Android Module Installation
Old 12-13-2016, 07:55 AM
ohnoyuji's Avatar
ohnoyuji will become famous soon enough
That's interresting!
Didn't know the Sirius module would be in place....
This step is the most heart faint step, if something goes wrong, I guess the PCM won't power up.....
Originally Posted by ddaarr
To install the new board the porsche sirius midule needs to be removed. I dont subscribe so i didnt care.
  #62
Old 12-13-2016, 07:57 AM
ohnoyuji's Avatar
I wouldn't splice too many wire, if you want everything to be reversible.
Originally Posted by wkearney99
If you're going to go through this much work, wouldn't it be better to splice into where-ever that AUX cable goes?
  #63
Old 12-13-2016, 07:59 AM
ohnoyuji's Avatar
Same here, I tuck the stereo cable thru the brim of the armrest console, then slips the rest in between the carpet and the bottom of the center console.
Totally reversible....
I tucked the 3.5mm cable on the edge of the center console. The seat is all the way back. When its moved forward the cable is hidden.
  #64
Old 12-13-2016, 08:05 AM
wkearney99's Avatar
wkearney99 has a spectacular aura aboutwkearney99 has a spectacular aura about
Everything goes through a connector, somewhere. No doubt that lead from the armrest goes through one at some point. Trace the wires, find the connectors and then decide how to best integrate with the wiring. I mean, if you're going to go through all this effort it seems kinda foolish to skimp on the last step.
  #65
Old 12-14-2016, 08:04 AM
ohnoyuji's Avatar
The whole mod, I would say is fairly easy, no split wire.
My experience is that breaking a wire bundle can cost alot and time consuming.
Without proper tool, it might not be easy to re-pin the wires.
Especially if you DIY this project.
  #66
Old 12-23-2016, 01:51 AM
ddaarr's Avatar
ddaarr is an unknown quantity at this point
Why don't you stuck the box like I did, behind the glove box?
This panel is only hold down by 1 screw. and two clips.
I tried to remove the glove box but it was stuck on the right side. I couldn't figure out what was holding it up. I also had a tough time with the A/C plumbing for the glove box. I'll try the glove box when I have time.
  #67
Old 01-24-2017, 02:27 AM
ynor's Avatar
ynor is an unknown quantity at this point
This project looks very interesting! Excellent work!
I live in Norway, and the FM band is now closing this year. The only possibilities to hear radio is by using DAB+ or internet streaming. As such, I would really like to find a usable solution to integrate DAB+ to the PCM3.1. Does the Android interface have DAB+, or is there any way to integrade DAB+ with the Android or multimedia interface?
  #68
Old 01-31-2017, 04:12 AM
ynor's Avatar
Would an universal Android USB DAB+ adapter work with the Android unit, like this one:
http://www.seicane.com/high-quality-...tional-antenna
https://www.solidrop.net/product/ext...avigation.html
or this one:
https://www.aliexpress.com/item/Joyi...693146746.html
The Android DAB+ adapter comes with software, and I would be great if this could be a solution.
  #69
Old 01-31-2017, 09:33 AM
ddaarr's Avatar
The Android module I installed had USB inputs. It works like the USB on a laptop or computer. For example, I have a wireless keyboard on one of the usb inputs.
  #70
Old 08-24-2017, 05:58 PM
jarge11's Avatar
jarge11 is an unknown quantity at this point
I have the 11 Speaker BOSE system. PCM3.1 with V2.64 software.
If i order this kit. will all speakers work even though it is only a stereo input? I suppose it would be the same as plugging a normal 3.1m jack to jack cable in to the AUX?
  #71
Old 08-24-2017, 06:10 PM
jarge11's Avatar
Is it possible to use this video interface unit together with another android smart TV box instead of the android sat nav box.
Would the existing PCM touchscreen work?
  #72
Old 08-25-2017, 10:21 AM
twcv's Avatar
twcv is an unknown quantity at this point
Great post and work. If I was not stuck with apple I would surely follow your lead here.
  #73
Old 10-28-2017, 07:08 PM
Raph Wayne's Avatar
Raph Wayne is an unknown quantity at this point
Can some one please show how you take off the back up camera on the interface? I can't figure it out
  #74
Old 11-03-2017, 11:44 AM
ohnoyuji's Avatar
Look at my post #32, the camera removal is at the "initial setup icon"
  #75
ohnoyuji's Avatar
Yes, the stereo output to all speakers.
Quick Reply: DIY - 958 PCM3.1 Video Interface and Android Module Installation
