Tailgate issue with 2011 Cayenne Turbo
Hello, I have an urgent problem with the tailgate of my cayenne. The tailgate is stuck shut and refuses to budge either electronically or manually. I did not realize it was open and it drained my battery the next morning. I got it to lock, but could never get it to open.
My best guess is that that day a friend of mine pressed the lock position button on the trunk and then closed it completely. It unlocks, whirrs, then locks back. I get no kind of warning lights or beeps. I attempted to remove the fuse for the tailgate controls and try again, still no use. No controls on either of the two keys or the car itself work.
I have a ladder stuck in the back and the only way it is coming out is through the trunk. Is there anything I could try or should I opt out taking it into the dealer? I could really use some help as quick as possible!
I believe if you open the panel on the inside of the tailgate (you'll have to crawl in there from the back seat area) there is a emergency release. It's there in case you're kidnapped and forced into the trunk. US Federal law requirement.
As far as getting the ladder out, sunroof?
Just went out and looked at mine - nope. No release. Guess they figured out it would be difficult to trap someone in the rear compartment. Bummer. I know I saw an emergency trunk release on some SUV (probably wife's Lexus RX350) where it made absolutely no sense.
BTW - when you say you "managed to get it to lock.." - perhaps something was stuck in the opening keeping it from locking? And that something is now jamming the tailgate from lifting up? Maybe try lifting as you press the release button? Or pushing in while pressing the release button (in case it's keeping the lock mechanism from releasing)..
Don't want to state the obvious, but did you check that the fuses were actually good? I'd want to know they're passing voltage. Throw a volt meter on the fuse to be sure.
The manual indicates this as an emergency procedure:
http://www.porscheownersmanuals.com/...ng-and-Locking
UPDATE: Figured out the problem after a bit of searching around. The car sent a fault code and won't allow the trunk to open. I am going to have to get it reset. Thanks for all the help from everyone! The tailgate is functioning, just not operating.
Is this a fault code that can be reset in the field using tools like the Torque app and a Bluetooth OBD2 module? Or iCarScan?
Tailgate issue
What was the fault code and how did you reset it. Everything still working without any parts replaced ? My tailgate won’t unlock or lock and has to be emergency opened. It is a 2013 turbo Cayenne with power tailgate. I’m thinking the power latch has failed does anyone have any more info on this issue
