QuiCk Question ...!
Old Jan 6, 2008 | 01:47 PM
CayenneOFDeatH's Avatar
CayenneOFDeatH has a spectacular aura aboutCayenneOFDeatH has a spectacular aura aboutCayenneOFDeatH has a spectacular aura about
Exclamation QuiCk Question ...!
heeey Guyz Am still figuring out a way to fix roof rails on my 06 CTT with pano roof ,, i was surfing the and i came a cross 2 kinds of rails other than the cross one the both look the same and go the same way from the rear to the front on is called roof rails and in the descreption says "Not available for vehicles with Panoramic Roof System " and the other is called drip Rails but only says "Elegant complement to the Roof Rails, in Aluninium look finish" so wht do think Guys ? are they diffrent or only names ? are the drip rails goin to fit or not ??
THNX in Advance guyz
Old Jan 6, 2008 | 02:24 PM
canberk's Avatar
canberk is infamous around these parts
Drip rails are different. Roof rails are rails that are on the sides, drip rails are in the middle of the roof rails if you have any. They are sold in 3 or 4 pieces sets and sticks to your roof. Roof rails and drip rails are different!
Old Jan 6, 2008 | 02:26 PM
canberk's Avatar
For your information. The rails in the middle are drip rails...
Old Jan 6, 2008 | 02:54 PM
ooooo i c now thnxxxxx alot
Old Jan 6, 2008 | 03:04 PM
canberk's Avatar
Drip rails are waste of money I think. You can only see them if you park your car in front of your window and look from 2nd or 3rd floor of your home...
Old Jan 6, 2008 | 03:05 PM
canberk's Avatar
And here is an off topic question for you. After all those mods, are you still under warranty with your ctt?
Old Jan 9, 2008 | 08:32 PM
GossettPorsche's Avatar
GossettPorsche is infamous around these parts
if you have the pano roof the only thing you can do is get the adjustable roof racks. the rails will not fit. should be pretty cheap to pick up a set though, and you can put them on in like 5 min. if you want something sleeker, you could pick up a set of the T reg ones, they also fit, and are a bit more aerodynamic.
Old Jan 10, 2008 | 05:01 AM
wht are the T reg ones ??
Old Jan 10, 2008 | 05:04 AM
belive or not i am
Old Jan 10, 2008 | 11:07 AM
the ones from a VW Touareg. they slide together to make a more aerodynamic "spoiler". you can get them in black or silver.
Old Jan 10, 2008 | 03:13 PM
i want the ones that slide from the rear to the front not from the left to the right the look more sportier ;P ... but can i fit the VW touareg ones that slide from the rear to the front ?????
Old Jan 10, 2008 | 04:55 PM
Dr_jitsu's Avatar
Great handle....doesn't calling your vehicle "Cayenne of Death" void the warranty?
PorscheEnthusiast
Nov 13, 2015 02:23 PM
terminal_ac
Sep 12, 2015 03:26 PM
GetALife75
New Member Introductions
Sep 3, 2015 12:22 PM
