CayennePorsche's SUV. Cayenne, Cayenne S, and Cayenne Turbo message forum.
Welcome to 6SpeedOnline.com!
Welcome to 6SpeedOnline.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join 6SpeedOnline.com today!
My Cayenne S 2004 is loosing coolant, lots of it.
I checked and all the hoses are fine, the coolant recipeint is fine too.
Looking under the car I see a lot of coolant coming in between the gearbox and engine.
Are there any hard to find hoses Im missing?
This ad is not displayed to registered and logged-in members. Register your free account today and become a member on 6SpeedOnline!
I've seen a lot of comments about coolant tube replacements on another forum.
this happened to my dad about 3 years ago and all the dealer did was swap the coolant tubes i think, but i dont remember all the details. goodluck man
1981 Cessna 421 Golden Eagle
2008 Porsche 911 Targa 4S To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
2004 Porsche Cayenne V6 - Eibach Springs, renspeed exhaust tips, 20" BBS CK's. turbo body kit coming soon
2010 Audi A4 - DD, 20" BBS CH-K's. H&R Coilovers
Also, there's a bulletin asking dealers to replace the square sealing rings between the tubes and the pump with o'rings.
You have a 2008, question was regarding a 2004. Different setup. Very likely it is the coolant pipes, as already stated multiple times. Most often, when the pump fails it is due to a noisy bearing, and doesn't leak coolant, but it does happen.
Mine dumped all my coolant from my wifes car. Luckily I still have/had my extended warantee and it was fixed at dealers expense. From what I understand this is a common problem...
__________________ Alan 01 996TT Proto 650 04 Cayenne Turbo Proto Stg2 01.5 WB S4 Avant KMD Tuned Gt28RS 635hp (low boost @22PSI)
