Does lowering the air suspension affect reliability ?
CayennePorsche's SUV. Cayenne, Cayenne S, and Cayenne Turbo message forum.
Welcome to 6SpeedOnline.com!
Welcome to 6SpeedOnline.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join 6SpeedOnline.com today!
my guess is everyone will say no. but I think YES it does cause more stress on components that otherwise would not be under normal conditions at factory height.
i don't have the schematic diagram of the air suspension, so im hoping this can be answered on the board.
it depends how the suspension is designed..
does it act like a coil over system where height can be adjusted without compromise to the strut itself, or perhaps like lowering springs that forcefully compress the stock shocks ?
this may be a bad comparison but you get the idea..
go to www.teile.pl and you can see the hole porsche cayenne build up....
the cayenne air suspension is a combination of air bags to lift and lower the cayenne and a hydraulic suspension ... the hydraulic suspension is connected to an oil extension.... when you lower down the hydraulic suspension let flow some oilback to the extension reservoier....
and the hydraulic suspension is adjustable in 3 modes to let them react fast mid or slow......
so you can drive in low mode 50.000 miles on a good street and the suspension isstill fine
you can go 10.000 m8les in the dirt and your (hydraulic part of the) suspension is dead...
I've got 65K miles on my CTT and I've never had any suspension related issues.
I also had the TA module installed about 15 K miles ago with zero problems
I also have the TA module and drive in the Low level 90% of the time. This means that the car lowers itself to the Loading level every time I lock it. It then raises back up to the Low setting when I get back in. That's a lot of up and down and still no issues.
"so you can drive in low mode 50.000 miles on a good street and the suspension isstill fine
you can go 10.000 m8les in the dirt and your (hydraulic part of the) suspension is dead... "
come over to austria and take a look on the sachs hydraulic suspension on my cay s with air suspension, it was a porsche testcar bevor
11.500 km ( around 8.000 miles) engine dead and also the hydraulics of the frontsuspension is dead...
the used the car in dresden to show the customers how to drive offroad,,,, an i mean realy offroad.....
the airbags still fine, but the sachs hydraulic suspension is on the end....
