Go Back   6speedonline.com Forums > Porsche (Present) > Cayenne
Cayenne Porsche's SUV. Cayenne, Cayenne S, and Cayenne Turbo message forum.
Welcome to 6SpeedOnline.com!
Welcome to 6SpeedOnline.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join 6SpeedOnline.com today!
Reply
Thread Tools Rate Thread Display Modes
Old 11-05-2009, 05:28 PM #1
futheman is on a distinguished road
How important is the coolant pipe upgrade on an 04 Cayenne TT?
I have found a couple of low mile 2004 Cayenne Twin Turbos. Everything checks out on them, but they have the plastic cooling pipes and were not upgraded to the aluminum ones. From what I've seen, it's expensive to upgrade.
Should I look for an 05 or would it be safe to buy an 04 with plastic pipe?
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on 6SpeedOnline!
Old 11-05-2009, 05:37 PM #2
Adman is on a distinguished road
I just bought an 04 but mine has had the upgrade done. It's something that will have to be done sooner or later and really isn't that expensive IMHO. If you can find a clean 04 that checks out well I would go for it.
Old 11-05-2009, 10:18 PM #3
huskyfan23's Avatar
huskyfan23 is infamous around these parts
If there isn't a warranty, move on. It's an expensive repair. Some members have gotten it repaired pro bono, but that doesn't necessarily mean you'll get it.
-'04 Porsche CTT
-Mods: EVOMS V-Flow Intake, 2ndary Cat Bypass
Old 11-06-2009, 03:08 PM #4
the head's Avatar
2004 Porsche Cayenne
My Garage
the head will become famous soon enough
If you have to take it to the shop, it's over $1000 to get fixed. If you were to fix it yourself, it'd be less than half that. Mine were replaced under warranty.
04 CTT
Fabspeed Bypass Pipes, IPD inlet, Evoms V-flow
03 GSXR1000
KWS stage 2, full Ohlins
Old 11-09-2009, 04:45 PM #5
2muchtime is a splendid one to behold2muchtime is a splendid one to behold2muchtime is a splendid one to behold2muchtime is a splendid one to behold2muchtime is a splendid one to behold2muchtime is a splendid one to behold2muchtime is a splendid one to behold
Mine happen taking it to my mechanic's for a service, came outside to show him the items I requested for service and radiator fluid every where, he told me he has to take off the top half that the plastic lines run along the block and the heat is to much for the plastic. my cost was 485.00. great mechanic
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
Old 11-09-2009, 05:46 PM #6
I decided to pass on the Cayenne T's I was looking at since they still has plastic tubing. Seemed like a ticking time bomb.
Thanks for the info.
Old 11-09-2009, 06:48 PM #7
porschespeeddemon's Avatar
porschespeeddemon is a splendid one to beholdporschespeeddemon is a splendid one to beholdporschespeeddemon is a splendid one to beholdporschespeeddemon is a splendid one to beholdporschespeeddemon is a splendid one to beholdporschespeeddemon is a splendid one to beholdporschespeeddemon is a splendid one to behold
Send a message via Yahoo to porschespeeddemon
Quote:
For $485 I would make sure he did the main lower pipe as well. If not, you'll be back. And this isn't just Cayenne turbo specific, it is all first generation Cayenne V8s. Realistically, I wouldn't let this stand in the way of you and the car you want.
2004 Cayenne Turbo- Titanium/Black
Old 11-10-2009, 01:24 AM #8
rockstardoc's Avatar
2006 Porsche Carrera
My Garage
rockstardoc will become famous soon enoughrockstardoc will become famous soon enough
I have an '06 TT with 49,000 miles. Coolant slowly began to leak and dealer took care of the plastic coolant pipes. They replaced them with the aluminum ones. Definitely an expensive fix. Luckily just made it at the end of the warranty period.
So it really doesn't matter if you get an 04 or an 06 for that specific reason. It can still have the same coolant problem.
2006 Carrara White 997 C4S
2006 Cayenne Turbo
Old 11-10-2009, 10:29 AM #9
str8blst's Avatar
str8blst is a splendid one to beholdstr8blst is a splendid one to beholdstr8blst is a splendid one to beholdstr8blst is a splendid one to beholdstr8blst is a splendid one to beholdstr8blst is a splendid one to beholdstr8blst is a splendid one to beholdstr8blst is a splendid one to behold
Mine went over the summer and dumped coolant all over my driveway. I believe the fix was over 1500 from the dealer.. thank god I had my car CPO....
Alan
01 996TT Proto 650
04 Cayenne Turbo Proto Stg2
01.5 WB S4 Avant KMD Tuned Gt28RS 635hp (low boost @22PSI)
Old 11-10-2009, 11:21 AM #10
intheflesh has a spectacular aura aboutintheflesh has a spectacular aura aboutintheflesh has a spectacular aura about
what years does this problem effect? i dont check the board often; this is the first time i have ever heard something about it.
i am plaaning on bringing my car in for its 60K service this week, its an 06' Cayenne S. should i have it replaced?
Old 11-10-2009, 12:16 PM #11
Quote:
He did replace the main lower as well..
Old 11-15-2009, 10:17 PM #12
Dual Cams's Avatar
2006 Porsche 911
Dual Cams is on a distinguished road
Send a message via Skype™ to Dual Cams
You'll see most of them on 2003 and 2004 Cayenne S and Cayenne Turbos and some early production 2005 Cayenne S and Cayenne Turbos. Very little on the 2006 Cayenne S and Cayenne Turbos.
During the 60,000 mile service per Porsche maintenance check list you need to check the coolant system. Most dealers and small shops does not pressure test the coolant system so that's something you want point out to them. Personally I would not spend the money to replace the coolant pipes unless they are cracked but again is your car and the dealers can not tell you what to do. Is all up to you... good luck
__________________________
"I Drive Porsche Passion"
02 996 X51 GT3 Aero Kit (sold)
05 997 C2S
09 BMW 535i
Old 11-16-2009, 09:36 AM #13
SeattleBum will become famous soon enoughSeattleBum will become famous soon enough
Another thing to check out (as I found out recently) is there are two plastic coolant lines inside the intake manifold. These can also crack. Ask me how I know! 100% of my coolant basically went into the manifold and straight out my exhaust while crusing at 70mph on the hwy. Poor sucka behind me didn't know what happened when all of a sudden his windshield was drenched in coolant and water.
I was out of warranty and it cost $2k to fix and upgrade the pieces to the new steel-braided versions. I'm still pissed and think it should have been a recall fix but I guess not quite enough have failed to recall...though enough so that they upgraded the part!
2005 Cayenne Turbo w/ TechArt stuff
Old 11-16-2009, 06:20 PM #14
pct2005 is on a distinguished road
05 here, had the leak, car was cpo'd, covered under warranty
Old 11-16-2009, 10:14 PM #15
Do you have part numbers for above repair? There is no coolant inside the intake manifold, or any "steel-braided" coolant lines.
Reply
Tags
cayenne, coolant, fliud, fluid, leak, leaking, pipe, pipes, porsche, problem, radiator, recall, tsb, turbo, years
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
User CP
Visit our Sponsors
6SpeedOnline.com
Advertising - Jobs - Privacy Policy - Terms of Service
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Copyright Internet Brands
