Secondary Cat Bypass Pipes
Trying to install some secondary cat bypass pipes on my 05 cayenne turbo.
How do you get access to the nuts on the top position of the cats? I don't see any room to move and turn the ratchet after successfully getting the socket onto the nut?
The other two that I did get access to are frozen with rust. I sprayed some liquid wrench spray onto the nuts but there was no real way of even spraying the passenger side nut on the top position of the 3 nuts.
I know there are a good handful of CT owners that have these. For the ones that did it themselves can anyone lend some advice on how you gained access to the top nuts on both cats but more so on the passenger side 2ndary cat?
I have done this more than a handful of times since it comes with the territory when fabricating your own exhaust.
The best answer here is a combination of a ratcheting 13mm flex head wrench:
AND a ratcheting half moon 13mm wrench to give you the extra clearance to turn the nut around the pipe
I will go to sears this week and try again with both! Thank you!
The nuts are brittle and stripping (thanks for the half moon and articulating ratchet recommendations...bought both). Not enough space to get my Irwin tool sockets on the nuts any other suggestions?
Would you trust an average joe at a muffler shop wrenching the nuts off and installing the bypass pipes?
Yes, there is little for them to mess up and they would have experience working with seized exhaust nuts.
Also, if you have the space, buy a set of Irwin nut extractors. They are made to "cut" into rounded nuts for removal in these types of situations
These tools are not a must, it just makes the job much much easier. And yes, the 958 would have similar space constrictions, so I would advise the same.
I'll post a few pics after i install my pipes sometime late next week.
I had Suncoast Porsche install Fbspeed Cats for me on my 2014 CTTS.
I bought them from Suncoast as well. Simple bolt on. Nice growl on start up. Zero drone or rattle. Low rumble at all times. Nice. MPG + 1,2 on highway. Noticeable increased response upon power demand at speed. Obvious proof, when they breath better they run better.
