Diff and Transfer-case fluid amount Cayenne S 2003
Old 06-30-2016, 12:51 PM
Domino's Avatar
Domino is on a distinguished road
Could anyone, that has done DIY differential and transfer-case fluid change, tell me what amount do I need. I'm starting to notice noises from front diff, so I'll change it in all three. Since I have this car for a year now, I think it's time.
Old 06-30-2016, 01:01 PM
dan87951's Avatar
dan87951 is a name known to alldan87951 is a name known to alldan87951 is a name known to alldan87951 is a name known to alldan87951 is a name known to alldan87951 is a name known to all
How many miles are on your car? I have a video on youtube that might be helpful for the rear differential. My car is a 2005 Turbo so don't know if they are the same as your S.
Old 06-30-2016, 01:23 PM
Domino's Avatar
I have 132'000Km, it's about 80'000 miles. I've changed AT fluid 3k's from now. But somehow didn't thought about diffs and tcase. I know how to change fluids. I need only amounts. It will be my only car for this weekend, gf will be visiting her parents, so when I pull it up, there's no chance for getting more soup.
Old 06-30-2016, 01:28 PM
dan87951's Avatar
At 21 seconds I list the fluid and amount that is required. This is directly from the Porsche shop manual.
Old 06-30-2016, 01:33 PM
Domino's Avatar
Thank you, Dan!
Old 06-30-2016, 01:44 PM
Domino's Avatar
Oh, one more question. Doesn't it, after draining old fluid, needs to be flushed with something to get all particles out, if there is some.
Old 06-30-2016, 02:06 PM
dan87951's Avatar
No problem! No flushing required. If you're noticing lots of metal shavings that would require flushing you more than likely have a big repair bill coming.
Old 07-04-2016, 01:32 PM
Domino's Avatar
I've changed all fluids - no metallic particles, just brownish stinky goo. Although noises were coming from right wheel bearing. So diff is fine, I guess.
Old 07-05-2016, 03:34 PM
dan87951's Avatar
Sounds like your diff it healthy. Wheel bearing does not sound fun! Enjoy!
Old 07-09-2016, 05:45 AM
dan87951's Avatar
I finally did a front differential fluid change video for our cars. You will need to modify (cut down) a 8mm allen in order to remove the fill plug. Good luck!
Ronny-
05-13-2020 03:11 PM
magoochi
06-12-2016 09:07 AM
justinammerlaan
04-20-2016 06:20 PM
Gene G
04-15-2016 10:47 PM
msgm1
04-13-2016 12:13 PM
Quick Reply: Diff and Transfer-case fluid amount Cayenne S 2003
