Notices
Garage Forum Share pictures of your garage with the rest of the 6speedonline members. Learn about Garage flooring, painting, art, and more in this forum.
House furnace for heat in garage?
Old 11-25-2008, 05:30 AM
TurboTodd's Avatar
TurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond repute
Hi all
I have an attached 2+ car garage. The garage shares two heated walls with the house and is well insulated. Most of the time I just leave the house to garage door open it stays warm .. for now. When it starts to get really cold I'm sure I will need more heat. I was thinking about just running a duct off my house furnace into the garage. Anyone ever do this? Looks simple to me. If I do this the adder would be I would have air in the summer.
Old 11-25-2008, 07:19 AM
function12's Avatar
function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !
Yes that will work. You might want to insulate your garage door. They sell kits on ebay(very pricey) or you can buy foam board at your building center and do it yourself.
Old 11-25-2008, 10:29 AM
TurboTodd's Avatar
The garage door and the man door are both very well insulated. Right now it is 35f outside and windy and it is 61 in the garage. Thats OK now but when it gets cold I could be in truouble. I think I will give the ducting a try.
Old 11-25-2008, 11:48 AM
.:Raul's Avatar
.:Raul is a splendid one to behold.:Raul is a splendid one to behold.:Raul is a splendid one to behold.:Raul is a splendid one to behold.:Raul is a splendid one to behold.:Raul is a splendid one to behold.:Raul is a splendid one to behold
if you choose to bring a duct over make sure you insulate the garage door as stated earlier
you can also put in a heater. this one sells for $100
http://store3-store.stores.yahoo.net/ingahe.html
Old 12-15-2008, 09:27 AM
Obie1's Avatar
Obie1 is infamous around these partsObie1 is infamous around these partsObie1 is infamous around these partsObie1 is infamous around these partsObie1 is infamous around these partsObie1 is infamous around these partsObie1 is infamous around these partsObie1 is infamous around these partsObie1 is infamous around these parts
Are these kinds of heaters ok to use on a sustained basis- is there a thermostat you can set and just leave alone?
Old 12-15-2008, 01:09 PM
TurboTodd's Avatar
I ended up with a Dayton electric heater. Works well so far but has not gotten real cold yet. At 20 degrees outside it keeps my garage at 70 with no problem Just do a internet search for electric garage heater.
Old 12-15-2008, 04:21 PM
negawatt's Avatar
negawatt is on a distinguished road
You made the right choice from a comfort perspective.
I would be concerned about maintaining comfort in the house during summer/winter extremes depending on how your HVAC system is setup/sized. Also, your (probably) single thermostat can't "see" your garage so you wouldn't have had very good comfort control there either.
Dayton makes heaters that are used fairly widely in industrial settings so it was a good choice.
The only remaining concern is cost. Depending on your utility rates it can be much more expensive to use electric heat. It's also less efficient.
Old 01-13-2009, 03:55 PM
mustangrodtp's Avatar
mustangrodtp is on a distinguished road
How do you attach the foam board to the garage door? Probably a dumb question, but I am not really handy around the house.
Old 01-17-2009, 12:01 PM
gekko's Avatar
gekko will become famous soon enoughgekko will become famous soon enough
Some links:
I was searching for the same and here are some links that might help:
http://forum.doityourself.com/insula...nsulation.html
Blanket from Home Depot - Have heard mixed reviews:
http://www.homedepot.ca/webapp/wcs/s...k=P_PartNumber
I've also read on some forums, people used Refextic material - cutting to shape and then gluing to the inside of the door.
Make sure to use something like this first in all the small holes along the side of your garage. I applied some last week and made a huge difference (in my case)
I hope this helps - I currently have a single garage and don't want to invest too much right now, as planning to build my own dream home in the next few years.
Old 01-17-2009, 01:40 PM
TurboTodd's Avatar
Update.......
The Dayton electric heater was a good choice for me. It is -8 out right now and it is +70 in my garage. The heater runs about every 20min. for 5min. when it is this cold
My electric bill was up about $30 from normal. Thats not bad considering in the winter I use more electric power for everything from bathroom heaters to the stove and lights. My cars, dogs and me are very happy with it.
Old 01-17-2009, 03:06 PM
Gekko looks like I have a spring project. Thanks for the info!!
Old 01-19-2009, 08:11 PM
cobramadness's Avatar
cobramadness will become famous soon enoughcobramadness will become famous soon enough
Does the foam board make a big difference? I'm thinking of doing this to my garage door.
Old 01-22-2009, 12:28 AM
Phrost's Avatar
Phrost is on a distinguished road
Attaching foam board to your garage door should make a difference... The high end insulated steel garage doors we carry at my work are just filled with a nice foam inside of them. Make sure the weatherstripping around where the door meets the frame is good too.
Old 01-28-2009, 12:58 PM
wrigh003's Avatar
wrigh003 is on a distinguished road
Originally Posted by TurboTodd
Hi all
I linked over here this morning, saw this, thought I'd post.
Most places, it's against code to have HVAC ducts enter the garage, due to the possibility of carbon monoxide traveling through the ducts and entering the house. Check your local rules.
That's why you always see folks with a window unit or a mini-split system heating/cooling attached garages.
Old 09-11-2010, 05:50 PM
RhinoArt's Avatar
RhinoArt is on a distinguished road
Have a Furnace for House im My Garage
Can I tap off the house furnace which is located in my garage to heat the garage?
Quick Reply: House furnace for heat in garage?
