Lambo Satellite Radio
Old 11-06-2010, 08:55 AM
scottbrowns's Avatar
scottbrowns is on a distinguished road
Hey guys I have a 2008 Gallardo and I desperately want to add satellite radio. What are my options? I currently use my Iphone with the XM app but it is annoying to have to do this all the time. Are there any other suggestions out there?
Old 11-07-2010, 09:10 AM
Hua's Avatar
Hua
Hua is offline
Hua has much to be proud ofHua has much to be proud ofHua has much to be proud ofHua has much to be proud ofHua has much to be proud ofHua has much to be proud ofHua has much to be proud ofHua has much to be proud of
Short of replacing your factory head unit with an aftermarket unit and plug in the XM antenna?
Old 11-07-2010, 03:25 PM
Yes I wanted to avoid taking out the factory head unit. Any other thoughts?
Old 11-11-2010, 06:43 PM
Hua's Avatar
Hua
Hua is offline
Are you totally against using a dock-and-play XM radio? You can wire those easily to feed into the factory antenna plug cable, and tune your FM channel to like 90.3 to listen to your XM radio.
Does the RNS-E not have satellite radio capability?
Old 11-11-2010, 06:55 PM
djantlive's Avatar
without new HU, your options are to use FM modulator.
Old 11-12-2010, 06:25 AM
snowrider204's Avatar
snowrider204 is on a distinguished road
I also wanted more out of the factory head unit. I finally decided to replace the head unit and I also replaced the speakers. Way better!!! Much easier to use!!!
Old 11-12-2010, 03:26 PM
Hua's Avatar
Hua
Hua is offline
You can also have a JL Audio CleanSweep CL441DSP installed. It allows integration with factory radios, eliminating the need for sub-par FM modulators.
There IS an aux input with the factory head unit, isn't there?
Old 11-12-2010, 08:56 PM
Thanks for the help guys. No there is not an AUX in on the head unit.
7thsign
12-12-2015 07:43 PM
calexand
11-05-2015 01:05 PM
007 Vantage
10-08-2015 08:35 PM
Mz3bo
10-01-2015 06:32 PM
Quick Reply: Lambo Satellite Radio
