FVD Brombacher - Macan Turbo Exhaust Pre-Order Special
We are excited to announce that we have finished R&D on the Macan Turbo Exhaust and we will have 2 mufflers to choose from in the next few weeks. We will be offering a Pre-Order Special* for these exhausts until September 20th, 2014.
1. Macan Turbo Sport Mufflers with Exhaust Valve and Tips - Pre-Order price will be $ 3,995 ($ 1,000.00 savings). Current lead time is 2-4 weeks.
+ 15 Hp & + 18 Tq Gain.
- 2.5" Tubing (63.5mm).
- 4 x 4"(101mm) Round Tips.
- 8.5 lb. weight savings over OEM mufflers.
- T 316 stainless steel for improved durability over T 304.
- Does NOT interfere with emissions and will NOT trigger the check engine light.
- ECU programming (software) is NOT NECESSARY.
- Electronic Valve Controller must be removed from the OEM unit and added to our muffler.
- Made in Germany.
2. Macan Turbo Sport Mufflers with Exhaust Valve - $ 2,995 ($ 1,000 Savings). Current lead time is 4-6 weeks.
+ 12 Hp & + 15 Tq Gain.
- Tips Not Included, you can reuse the OEM tips or aftermarket tips that fit the OEM mufflers.
- 10 lb. weight savings over OEM mufflers.
- Made in Germany.
This is the very 1st aftermarket muffler for the Macan 95B Turbo that includes a valve like the factory system. This allows our system to build the torque specified by Porsche by increasing the back pressure in the low to mid rpms and then acts a muffler bypass at higher rpms to give added horsepower. This is a very important feature that we decided to keep and build upon allowing for lower end torque and more rich deep exotic tones in the higher rpms. This feature also allows our mufflers to keep a quiet civilized tone while cruising and around the town when the valve is closed and creates raucous aggressive sounds with the valves open under full load.
The design and construction of our mufflers are vastly different than the common baffle plated mufflers stuffed with packing material that are common in the aftermarket. Ours are uniquely made with double perforated sound absorption tubes. The acoustic silencer absorption tubes are made in a trapezoidal pattern and are perforated with varying diameters, which isolate and dampen unwanted frequencies (drone). Perforated tubes at higher gas velocities, present much less flow restriction than baffle plates and consequently translates into larger horsepower gains at higher RPMs. Also they produce the aggressive gurgling sound and contribute to the low, deep tones that you hear when the electronic exhaust valve opens. The exhaust tips are a dual 4” round design and are double walled to dissipate heat, which means that they won’t tarnish as quickly as single walled tips. The design fit’s the factory cut outs in the bumper perfectly and is mounted via a ball style-connecting joint so they can be perfectly adjusted in all directions which allows them to be centered perfectly.
* This sale is being posted by FVD Brombacher Inc. (USA) and is valid to customers in North and South America.
- Made in Germany.
- Made in Germany.
FVD Brombacher - USA
Contact me directly to get the latest FVD forum member discount!
Rhonda Roxburgh
+1-954-571-2050 x 1
rhonda.roxburgh@fvd.net
Visit our online shop for an extensive selection of tuning and original parts www.fvd.net
Rhonda Roxburgh
+1-954-571-2050 x 1
3WDistributing
31
10-27-2017 01:26 PM
ECS Tuning - VW
08-19-2015 10:43 AM
ECS Tuning - VW
08-19-2015 08:58 AM
