Just released! Agency Power Valvetronic Exhaust for Macan Turbo
The Porsche Macan Turbo has become a hot platform to dial in the performance on while still be a very functional crossover SUV. The 3.6 liter engine features a V6 twin turbocharged system that puts 395 horsepower and 406 ft/lbs of torque. Similar to the Audi Q5 platform, the Macan's chassis offers 911 like handling with performance gains similar to the 911. As with most turbocharged vehicles, there are several restrictions that allow the vehicle to meet government regulations and manufacture demographic specifications. One of those restrictions is the exhaust system. Factory exhausts are designed to keep noise at a minimum and restrict the exhaust flow for emissions purposes. Turbocharged cars don't need any backpressure and would be very happy with a small dump pipe off the turbocharger only. Since the Macan Turbo is your sporty crossover, you need to have a fine balance between sound and performance.
Agency Power delivers an exquisite sound and performance with their new valvetronic exhaust system for the Porsche Macan Turbo. The exhaust is constructed of high quality 304 stainless steel which has been TIG welded for an OEM fit. Utilizing the stock tips or aftermarket OEM type tips, the dual muffler and midpipes have been polished to a show finish. Ideally, a single 3 inch exhaust would work perfect for this turbocharged vehicle. Because of the split muffler and twin turbocharger design, we utilize dual 2.75 inch tube which flows much better than single 3 inch piping.
To provide a comfortable sound when needed or a race inspired growl when wanted, the Agency Power exhaust uses a valvetronic designed muffler. The valves located on the tip side of the muffler can restrict the exhaust flow or open it up to change the exhaust tone. These valves are controlled by a vacuum solenoid that is activated by a remote key fob switch. The full catback exhaust is a great upgrade for Porsche Macan Turbo owners wanting a more aggressive sound combined with enhanced performance. Expect to feel improved throttle response and low end torque from the reduced restriction along with stronger mid and top end pull to redline. The exhaust is designed as an OEM replacement and no cutting or welding is required. The installation of the valvetronic components requires connecting to a vacuum source and running power supply wires for the remote module. All Agency Power products come with a limited lifetime warranty.
**OFFERING STEEP DISCOUNTS FOR FIRST COUPLE SYSTEMS IN EXCHANGE FOR PICTURES/VIDEO OF INSTALLED EXHAUST**
MalcolmV8
02-09-2016 09:57 AM
