Lapping a P1 at Laguna Seca
From a 90dB event on Monday. It was my first time on track with the P1, and we got 14 laps of track time. Despite the 2.3 sec of lost time between T5 and T6 due to noise restrictions, it's already looking very very good
Limiting factor right now is definitely the tires; the chassis and brakes in particular are ready for more. Driving the P1 on Trofeo's is like driving a race car on worn-out slicks, and I expect to see this car's laptimes tumble as better tires become available.
Epic, thanks for sharing! Is there enough regeneration to keep the batteries charged and thus the power unit at full chat for an entire session?
Interesting question. The video I posted was from lap 6 of the session. Looking at the video, the prior 2 laps were both within 0.4 secs, so the car had reached a steady state of sorts by lap 4. I didn't have a video recording the dash to monitor charge state; I'll add that to my list for next round.
Some people have said that the Trofeos don't give much more grip than the legacy PZero Corsas (not the new PZero Corsa System on P1) but wear a lot faster. This review in particular. Any truth?
http://www.tyrereviews.co.uk/Tyre/Pi...ero-Trofeo.htm
It feels softer overall than the Pirelli Corsa Semis. Its dry grip is excellent and seems to have a tiny advantage over it's predecessor. I cannot really tell about wet grip, since I didn't go to the limit. But don't be fooled, it wears out very quick! I had them mounted factory new on my Ferrari F430 and planned to have fun all day in Mugello. After a couple fast laps, it started to overheat despite proper pressure. Soon after, I got back to the pits with completely worn out front tyres. The mechanics have never seen something like that before. I want the Corsa Semislicks to come back!!
Looking at the actual scale on the graph the battery never gets below 80% of max, so even with much longer straights you're probably looking at many laps to wear it down. It also starts near 70% charge and still makes it to 100%, so the narrow width of the graph is likely making it difficult to tell how sharp those max charge peaks really are. Clearly if it starts at 70% and makes it to 100%, then starting from a trough of 80%, it must get to 100% and stay there for a while. Even though it doesn't recharge from the wheels during braking, the engine is still recharging it during braking and during corners and during TCS intervention, basically any time WOT isn't used. The real issue is that it uses more gas to do it this way but the relatively small, lower revving 3.8L V8 likely uses less gas than bigger higher revving engines when not recharging and not having a KERS system saves weight and improves brake feel.
10-06-2015 06:13 PM
