NEW RELEASE|BREMBO BBK for G63/G65
The Brembo B-M8 is an 8-piston monobloc caliper with four pads, suitable for rotors up to 420mm x 40mm (16.53” x 1.57”). This all-new caliper is specifically made for the front braking systems of trucks, SUVs and large high-performance sedans. As one of the largest calipers manufactured by Brembo, at 15.8 inches x 5.51 inches x 7.1 inches, the B-M8 required more than one thousand design hours, which included on-vehicle testing and casting technology development. The B-M8 is validated for torques up to 5700Nm (4204 lb ft).
The B-M8 is manufactured using a new, innovative 4D technology casting process, and is the first time this process has been used for automotive calipers. This casting process uses a technology that enables Brembo to engineer a design completely different from what is usually seen in the caliper market. With this technology, the casted caliper has technical features commonly used in racing billet or forged calipers. The B-M8 is casted with an internal fluid line versus the more conventional rigid pipe connections. The one non-visible bleeding screw allows for more safety and freedom in the design since it is better integrated into the overall design. The B-M8 is the most efficient body architecture and style and designed without constrains on the outboard caliper manufactured by traditional molds.
The B-M8 is available in four colors – red, yellow, black and new to the market white, with a few “optional” colors. The companion caliper, the B-M4, for rotors up to 380mm x 30 mm, is suitable for the rear braking systems of larger vehicles as well as front applications for smaller cars. The B-M8 and the B-M4 are ideal for a variety of trucks, SUVs, and sedans including, but not limited to Ford F-Series and Expedition, Dodge Ram, Toyota Tundra, Nissan Frontier, Land Rover Range Rover, Mercedes-Benz SUVs and Porsche Cayenne.
Developed to increase overall braking performance, the B-M8 exhibits consistent braking power under intensive conditions. The B-M8’s four pads provide a significantly larger braking surface, improving performance and pad wear, while communicating increased “bite feel” to the driver. Manufactured in the same plant as the company’s racing brake systems, the B-M8 leverages Brembo’s 40 years in motorsports in an advanced road-going high performance caliper.
https://youtu.be/TRGcJ5G2M3Q
Taking pre-orders now...Pleases contact us for special pre-order pricing....Thank you!!!!
3W Distributing LLC
5140 Rogers Street Ste C
Las Vegas, NV 89118
Website: www.3wdistributing.com
Facebook: 3wdistributing | Instagram: 3wdistributing
#1 BRABUS Dealer in North America | TECHART Authorized Dealer
Authorized Distributor for: BRABUS, TechArt, StarTech, BBS, Mansory, BREMBO, KW Suspension, H&R, Ohlins, FI Exhaust, and Much More....
WE SHIP WORLDWIDE....
3W Distributing LLC
Las Vegas, NV 89118
