P3Cars Vent Integrated Digital Interface For Your MINI!
Brought To 6Speed By Pelican Parts!
Connect with your car in an entirely new way. Why settle for just a boost gauge? Sporting features available in products 3x the price, this is a swiss army knife of performance data, with design and integration that won't spoil the clean lines of your interior.
- Plug and Play - install Quick plug and play install with zero cutting required. All power and ground connections come directly from the low profile concealed diagnostics port connector.
- Boost/Vacuum Display - High resolution boost/vacuum sensor and display showing actual manifold boost.
- Multiple Gauge Displays Boost/Vac, Coolant Temp, Intake Air Temp, Exhaust Gas Temp, Throttle Plate, Speed, RPM with Shift-light, Battery voltage and more.
- Peak Recall & Run Record - Recall the peak value from any mode, or record and playback 15 seconds of data from the current mode. Temperature peaks recorded in the background.
- Universal Aux Inputs - Includes additional inputs to optionally connect any 0-5v sensor with universal settings for display ranges and bar-graph displays from -999 and 9999 max values.
- On the Fly Configuration Menu - Lockout/Display off mode, English (PSI, F, MPH) or Metric (BAR, C, KPH) selection, Adjustable boost display resolution, Ambient Calibration for boost sensor and more!
ECS Tuning - BMW
09-16-2015 07:40 AM
ECS Tuning - BMW
09-10-2015 02:51 PM
ECS Tuning - BMW
09-04-2015 01:57 PM
ECS Tuning - BMW
09-04-2015 01:52 PM
ECS Tuning - BMW
09-02-2015 02:11 PM
