BRracing GTR Harness Bar
Have you ever tracked your Nissan GTR?
Do you plan on tracking or driving your GTR hard in the future?
Racing accidents happen every year, no matter how skilled and experienced a driver is.
Safety should be on the top of everyone's list when they are at the track, we have designed a bolt in harness bar that will install directly into the car with very minor modification made to the carpeting.
The bar is completely removable, uses factory mounting locations (no drilling or welding), the bar can be welded in for future use if desired. The objective of the bar is very simple and direct. - complete bolt in, using factory mounting points and attachments - no cutting of any factory elements, ease of installation - ability to have the system either complete bolt-in and removable, or can be welded in if desired - complete torsional rigidity and stiffness - support for harness sets with built in "click-in" tabs Features of the system are: - all units are powder coated to the color of choice - all units are made from 4130 chrom-moly, and complete TIG welded - all connection points are male/female clevis units, so no play, no flex - the main hoop base plate has both vertical and side support plates - base plate "can" utilize a hole to be drilled thru the floor to further enhance attachment and rigidity in multiple directions - down bars/X-brace can be removed with just four clevis bolts , and does not interfere with rear seat cushions - utilizes the strongest mounting points already in the car...the seat belt attachment locations and the car side frame rails
The bar is a 4 point harness bar system with removable X brace for future use of the back seats while still maintaining the main hoop in the car.
With this bar in place, it allows the ability to use racing either a 4 point or 6 point harness system in the car versus using the stock 3 point seat belt.
Upon ordering please let us know what color you desire for the bar to be powdercoated.
The bars are ready for delivery, please allow 3-5 days for powdercoating and shipment.
VID997
97
03-20-2018 02:23 PM
TitanMotorsport
Nissan GTR
09-23-2015 03:25 PM
JWrightPNH
09-17-2015 01:42 PM
