Nissan GTR Vendor Classifieds vendor classified area...do not post here unless you are a forum sponsor
Extreme Turbo System Performance parts for the NISSAN GTR!
Old 07-01-2013, 12:14 PM
XTR Performance's Avatar
XTR Performance is on a distinguished road
We are proud to announce that we are offering Extreme Turbo Systems products for the Nissan GTR! Anything you want from ETS we can get you at the best price possible!
ETS NISSAN GTR Twin Turbo Intake Kit
The ETS 3" stainless steel mandrel bent air intake kit for the 2009 - 2013 Nissan GTR was designed and extensively tested with performance in mind! Our intake kit will feed your turbos with the coolest, most dense air possible. This helps increase spool up, Torque and HP!
Options:
  1. Black Piping
  2. Brushed Stainless Steel
  1. MAF Adapters
  2. Speed Density Adapters
Features:
3" Mandrel bent stainless steel 1 piece construction.
Easiest installation possible. Doesn't require bumper removal and can be installed right at home in your garage.
Heavy duty mounting brackets to insure your intakes stay in place for the life of your vehicle.
ETS 4 Ply Silicone couplers and heavy duty clamps.
Amazing sound and performance.
Genuine K&N filters.
Tested and proven on 1200+WHP GTRs.
100% Made in the USA, right here at ETS.
Lifetime Warranty!
ETS CNC Ported Cylinder Heads NISSAN GTR
Features:
40 - 60 Horsepower Increase.
Fully CNC ported and hand smoothed.
Wire EDM performed to ensure maximum reliablity and wall thickness.
Flow benched for optimal performance.
Includes:
  • ETS 5 Axis CNC Ported Heads
  • Head Modification for high boost applications.
  • Serdi Valve Job (The best valve job possible)
  • Ferrea +1mm Intake and exhaust valves
  • Ferrea Dual Valve Springs
  • Ferrea Titanium Retainers
  • Ferrea Valve Locks
  • High-Temp Valve Seals
  • Valve Guide Seals
ETS Nissan GTR Downpipes
Exteme Turbo Downpipes are one of the highest flowing downpipes on the market with no restrictions. Most of our competitors downpipes use stamped 1/8" or 3/8" flange material which warp under high temperatures while our downpipes are constructed of 304 stainless steel and 1/2" flanges to prevent warpage and maintain a perfectly smooth surface. Downpipes can provide a noticeable gain in horsepower ranging from 50hp on stock turbochagers to over 100whp on upgrade turbochargers. It's important to note that downpipes will increase the sound of your exhaust since we removing the restrictive catalyitic converter from the system. These downpipes add a nice throaty sound under WOT and maintain a nice idle that fits the GT-R perfectly!
Features:
  • Increased Horsepower and Torque
  • Improved Turbocharger Spool, throttle response and transient response.
  • Deeper exhaust note
  • Stock Fitment (Bolts up to factory mid pipe and most aftermarket mid pipes that use factory locations)
  • Hand Tig Welded
  • Brushed Finish
  • 1/2" Thick Flanges
  • 304 Stainless Steel
  • Factory Mounting Locations
  • ETS Lifetime Warranty
ETS Nissan GTR Stainless Steel Exhaust System
The ETS GT-R 4.0" Stainless Steel Exhaust System is the largest and highest flowing exhaust system on the market. This exhaust has zero restrictions starting with a 4.0" mid pipe which routes into a full 4.0" cat back exhaust system and features a true 4.0" merge collector which routes into 4.0" mufflers and from the mufflers we use a 4.0" merge collector that routes into dual 3.0" mandrel bends for the exhaust tips and finish the exhaust system with polished stainless tips which will never flake like some of the chrome coated exhausts on the market.
Features:
  • Full Stainless Steel
  • Direct bolt on to factory Y-Pipe.
  • True 4.0" merge collector into dual 4.0" mufflers.
  • True 4.0" to 3.0" Merge collector from muffler to exhaust tips.
  • Stainless Steel Tips (not chrome / will not rust)
  • Largest GT-R exhaust system on the market.
  • Fully built in house.
Includes:
  • 4.0" Mid-Pipe
  • 4.0" Catback
  • All Clamps and Hardware Needed For Install
Note: Optional 4" Y-Pipe/Midpipe Available
ETS Nissan GTR Titanium Exhaust System
The ETS GT-R 4.0" Titanium Exhaust System is the largest and highest flowing exhaust system on the market. This exhaust has zero restrictions starting with a 4.0" Y-Pipe connected to a 4.0" mid pipe which routes into a full 4.0" cat back exhaust system and features a true 4.0" merge collector which routes into 4.0" mufflers and from the mufflers we use a 4.0" merge collector that routes into dual 3.0" mandrel bends for the exhaust tips and finish the exhaust system with polished Titanium tips which will never flake like some of the chrome coated exhausts on the market.
Features:
  • Full Titanium construction from the Y-Pipe Back
  • Includes Stainless Steel Y-Pipe.
  • Titanium Tips (not chrome / will not rust) Can be anodized with the "burnt look"
Includes:
  • 4.0" Stainless Y-Pipe
  • 4.0" Titanium Mid Pipe
  • 4.0" Titanium Cat-Back Exhaust
ETS Nissan GTR Street Intercooler Upgrade (Intercooler Only!)
The Extreme Turbo Systems GT-R intercooler is a direct bolt on upgrade for your GT-R. This intercooler features 40 charge rows.. That's 80 heat transfer plates! Which gives us more heat transfer area than any other intercooler on the market! This intercooler works great for stock turbochargers running moderate to high boost as well as bolt on turbochargers. The ETS GT-R Street Intercooler has interally offset and staggered fins so as charge air passes through the intercooler it's forced to split multiple times which results in cooler intake air temps. Cheaper intercoolers have straight through internal fins which results in much hotter intake air temps. The exernal fin pack is also offset and staggered but large enough to let air flow through to the radiator. Unlike some of the cores on the market which rely on a tumbling factory which blocks air flow to the radiator. Our intercooler is perfect for a street or track car. If you plan on upgrading to a larger turbo setup (30R, 35R, 37R, etc) we would recommend our ETS GT-R Race Intercooler which is the largest intercooler on the market and includes 3" pipng.
Features
  • Direct Bolt On. No extra piping or couplers needed.
  • Works with factory under tray
  • Works with factory crash beam
  • Triangled End Tanks (Excess welds cause fatigue to the metal, we minimize welding)
  • No Cutting
  • 40 charge rows / 80 heat transfer plates!
  • Made in the USA
  • Lifetime Warranty
  • Thicker cores available for high horsepower applications.
Options:
  • Custom Anodized Intercooler Color (Red, Blue, Black, Gold)
  • ETS Stencil
    ETS Nissan GTR Intercooler Upgrade Kit (Includes Intercooler Piping)
    We are proud to release our new Extreme Turbo Systems R35 GT-R Race Intercooler Kit. This thing is monstrous compared to the stock intercooler and all other aftermarket intercoolers. Before coming to the conclusion of using a large vertical flow we weighed all our options with a huge horizontal flow intercooler. The problem with the horizontal flow intercooler is you have to split the intercooler into two sections one for each bank. The bank using the bottom of the core would have considerably lower IAT then the bank using the top section of the core which would be hidden behind the crash beam and tucked behind the bumper cover. The tall vertical flow (ETS GTR Race Intercooler) allows for the exact same amount of surface area on both banks. This kit will feature 3.0" stainless steel piping (Flat Black, Gloss Black, Polished or Brushed) your choice of blow off valve flange TiAL, HKS, Greddy, Turbosmart and more!
    Features:
    • Largest Intercooler On The Market (22x14x4.5 Core)
    • Full 3.0" SS Mandrel Bent Piping
    • Bracketed Around Oil Cooler (Prevents Potential Leak)
    • Clears Factory Crash Beam
    • Clears Factory Bumper Cover
    • Clears Factory Under Tray
    • Clears Factory Fender Wells (Important When Fully Locked)
    • No Long Silicone Couplers
    • Breeze High Quality T-Bolt Clamps w/ Bridge (Won't Slip)
    • Works With Factory Blow Off Valve Pipes Or Aftermarket Stock Replacement
    • Blow Off Valve Pipes (Optional Upgrade - Check Drop Down Box)
    • Blow Off Valve Pipe Options Include - MAP Sensor Mounting, MAF Sensor
    • Mounting and Blow Off Valve Flange Choice
    Kit Options:
    • Intercooler Kit (Default)
    • Intercooler w/ Mounting Brackets. (Fits factory crash beam and bumper cover)
      3.0" Stainless Steel Piping (bracketed around the oil cooler to prevent a potential leak due to vibration/rubbing)
    • All 4 Ply Couplers and High Quality Breeze T-bolt Clamps.
    • Blow Off Valve Pipe 3.0" (Upgrade Option)
    • Your Choice Of BOV Flange (TiAL, Turbosmart, HKS, Greddy, Etc.)
    • MAP Sensor Connection (Default)
    • MAF Sensor Connection (Optional)
    • Brushed Finish, Powder Coated Flat Black or Powder Coated Gloss Black
    • Choice of throttle body coupler. (3.0" to 2.75" - Factory or 3.0" to 3.0" - Upgraded)
    The ETS GT-R Race Intercooler Clears Factory Bumper Beam, Bumper Cover, Under Tray, Inner Fenders (Important During Full Lock). The only trimming require is to the factory intake shroud to fit the larger intercooler. We will be making an optional air duct for the guys who want to remove the bumper completely and maximize your intercooler surface area. This will come at a later time.
Old 07-02-2013, 02:05 PM
All PM's replied. Thank you for your business everyone. Be sure to check out our other deals and ask us about package deal pricing!
Old 07-03-2013, 02:36 PM
Old 07-05-2013, 12:50 AM
Old 07-05-2013, 02:44 PM
Old 07-06-2013, 02:57 PM
Old 07-07-2013, 02:40 PM
Old 07-08-2013, 08:44 AM
Old 07-20-2013, 10:53 PM
Old 07-23-2013, 12:42 PM
AJUSA.com
997 Vendor Classifieds
10-08-2015 05:50 PM
Vellano Wheels
Nissan GTR
08-19-2015 06:43 PM
Nissan GTR
08-19-2015 02:11 PM
ECS Tuning - VW
08-19-2015 08:58 AM
Quick Reply: Extreme Turbo System Performance parts for the NISSAN GTR!
