Rotora Street Challenge Brake System for Nissan GT-R
Rotora Street Challenge:
Rotora's high-performance Street Challenge Brake System enables superior brake modulation while improving overall pedal feel to ensure equal distribution of weight transfer when braking.To achieve this proportional front-to-rear brake bias, Rotora’s brake systems are strategically engineered to work in conjunction with the original vehicle stock master cylinder thereby producing shorter stopping distances.In using larger calipers and discs made with stronger, lighter weight material, Rotora Brake System’s thermal capacity and brake torque is increased over the vehicles original brake system.These are the design enhancements that are demanded in high-performance street and track vehicles.All Rotora Brake Systems are fully compatible with ABS and traction control systems.All brake components are direct bolt-on systems for production vehicles with minimal modifications required.
Brake Specs:
F: Forged 8-Piston Orange Calipers / 405x36mm Carbon-Ceramic Discs
R: Forged 4-Piston Orange Calipers / 380x32mm Carbon-Ceramic Discs
Contact Ben for pricing and information
Email: benson@rotora.com
TEL: 626.813.7900 ext. 100
COMPONENTS/FEATURES:
-Rotora forged aluminum calipers with sequentially sized piston bore sizes engineered to each specific vehicle and to minimize pad taper wear for longer pad life.
-All Rotora calipers are fully forged (2024-T6) for optimal strength, stiffness and light weight.
-High temperature dust boots are included to reduce caliper maintenance.
-Rotora two-piece constructed billet 6061-T6 forged aluminum hat to reduce heat related stress and unsprung weight.
-Rotora Anti-Rattle Float Drive Hardware for two-piece discs systems to allow discs to expand and contract under extreme usage.
-Rotora 1 or 2-piece directional vented (heat treated) discs to increase airflow/cooling under severe braking.Slotted or drilled/slotted oversize discs up to 16” (405 x 36mm) to ensure increase thermal capacity while relieving the disc and brake pad surface free of excess debris.All discs are coated with anti-corrosion zinc plating as added rust protection.
-Rotora 7075-T6 billet aluminum forged caliper bracket (depending on application) to reduce unsprung weight.
-Rotora’s range from ceramic to carbon metal brake pads are designed to accommodate street to extreme track use with high co-efficient of friction and high temperature fade resistance.
-Rotora DOT compliant stainless steel braided brake lines to improve stiffer pedal feel and prevent brake hose expansion.
Brake Specs:
04-28-2022 12:38 AM
Vellano Wheels
Nissan GTR
08-19-2015 06:43 PM
Nissan GTR
08-19-2015 02:11 PM
