Go Back   6speedonline.com Forums > Japanese > Other Japanese Supercars
Other Japanese Supercars Toyota Supra, Honda NSX, Maxda RX-7, Lexus IS-F/LF-A etc.
Welcome to 6SpeedOnline.com!
Welcome to 6SpeedOnline.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join 6SpeedOnline.com today!
Reply
Thread Tools Rate Thread Display Modes
Old 01-19-2009, 07:47 AM #46
FaFaSupra is a splendid one to beholdFaFaSupra is a splendid one to beholdFaFaSupra is a splendid one to beholdFaFaSupra is a splendid one to beholdFaFaSupra is a splendid one to beholdFaFaSupra is a splendid one to beholdFaFaSupra is a splendid one to behold
very nice, I'll have to post some pics of mine. My PC crashed and I lost nearly everything so I will get some new pics. But nice rides.
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on 6SpeedOnline!
Old 01-19-2009, 07:55 AM #47
Quote:
Originally Posted by Raydius View Post
I've driven a lot of mk3, mk4, and SC300 -- Anything is possible with mods, but as a stock car, it has a lot of body roll and is slightly front heavy, therefore is real ****ty at quick transitions such as slalom or chicane type situations. There's a lot of rubber under the car, so max grip for sweeping turns is not a problem. The car just never feels nimble.
I thought it was because of the ~3600 lb curb weight, but almost every other car I've owned, even the w202 Mercedes, has been about as heavy but had much more nimble handling, even completely stock. I've never driven a 3000GT/Stealth, so can't compare directly.
it's all about suspension. Stock, they handle like crap. But you can make any car handle well and I have seen some really good ones. One of the reasons is that much of the weight is high on the car. But again look at the nissan GTR and how it handles and it has lots of weight high, so it's all suspension
Old 01-19-2009, 10:03 AM #48
blakez's Avatar
blakez is on a distinguished road
Mine handled totally different when I put my wider wheels on. Completely different car.
-green sc300 t67 single turbo
-white 996turbo
-gray cayenne turbo
-black international cxt
Old 01-25-2009, 03:40 PM #49
devster is on a distinguished road
I'm just starting to make some real progress on my sc300 project. Theres some really nice cars in this thread.
Old 01-25-2009, 09:23 PM #50
VegasSE's Avatar
VegasSE is a jewel in the roughVegasSE is a jewel in the roughVegasSE is a jewel in the rough
SUPRA MODS:
Engine:
Virtual Works 3.4 stroker
CP Flat Top Pistons
Carillo Rods (upgraded carr bolts)
Crower Balanced Billet Crank
Clevite bearings
ARP main studs
Program Billet mains
Line honed block
Fully polished and ported Virtual Works race head
+1mm Crower valves
Ferrea dual spring/retainers
L19 Head studs
HKS 280 Cams
Unorthodox Cam gears
Unorthodox Pulleys
BoostLogic crank pulley
BoostLogic Billet tension
Virtual Works Dual Rail 12 injector Intake Manifold
Accufab Throttlebody
Virtual Works Modified Oil Pump
Virtual Works Modified Water Pump
Toyota P/S pump (new)
Power Enterprises Kevlar Timing belt
Power Enterprises Kevlar Serpentine belt
Chromed Valve covers
Powerhouse Polished Spark Plug Cover
TTC Polished Brake Cap
TTC Polished ABS Relay Cover
Greddy Billet Oil Cap
ATI Lexan Spark Plug Cover
All Bolts Switched to Stainless Allen Bolts
Lines Converted to Braided
Polished Fittings
Extensive Chroming
TRD motor mounts
Turbo + Exhaust:
Virtual Works turbo header T6
Tial 44mm wastegate
GT47-88mm turbo (polished and coated) T6
Virtual Works anti-surge turbo insert
Custom SP (chromed) 6” cold air intake
Virtual Works Modified water neck (to fit large frame turbo)
Virtual Works stainless downpipe (recirculated)
HKS racing bov
HKS Hiper Titanium Exhaust
Cooling:
PWR Aluminum radiator
Sound Performance 5 inch race Intercooler
Custom Virtual Works 4” intake piping
Virtual Works Upper and Lower Intercooler Strap
Upper radiator hard pipe
Lower radiator hard pipe
Upper radiator cooling plate
Upper Radiator show plate
Trans + Clutch:
6 speed PPG Dog Engagement Gear Set
Tilton Carbon Triple Disc clutch
Custom 1pc steel driveshaft (cnc’d ends)
Virtual Works Driveshaft Loop
TRD LSD
TRD Trans Mount
Fuel System:
Weldon 2835 Fuel Pump
Aeromotive Fuel Pressure Regulator
Virtual Works Dual Fuel Rails w/1000cc Injectors
Custom AN Fuel Lines
Suspension:
Virtual Works custom rear suspension
Virtual Works mini tub
TRD Sway bars
Cusco carbon rear strut bar
DoLuck Cross Bar
Tein Flex coilovers
Tein EDFC controller
Titan Billet mount kit
Electrical:
Motec M800 Engine Management
HKS DLI Twin Power Ignition
Blitz turbo timer
AEM Boost Gauge
Defi Water + Oil Gauges
AEM Serial Gauge
FJO Wideband gauge custom mounted
TRD 10K Tach
Trunk relocated battery
Brakes:
Brembo 14 Inch Big Brake Kit Painted Lambo Verde
Slotted front + rear Brembo rotors
Goodrich Stainless brake lines
Wheels + Tires:
HRE 597R 18X10 front
HRE 597R 18X12.5 rear
BFG Gforce Drag Radial (345/30/18)
BFG Gforce ZR front (265/35/18)
Interior:
TRD Steering Wheel
TTC Drilled Performance Pedals
10% Tinted Windows
New Carpet 33,000 miles
New Factory OEM mats
New Factory Black Leather seats
SP Rear Seat Delete
Exterior:
DoLuck Late Model Front Bumper
Genuine TRD hood
Bomex side skirts
Clear Signal Markers
Smoked Side Markers
Smoked Taillights
C’s Short Throw Shifter
3M Clear Bra
Old 01-26-2009, 11:58 AM #51
NoXqcsMotosport has much to be proud ofNoXqcsMotosport has much to be proud ofNoXqcsMotosport has much to be proud ofNoXqcsMotosport has much to be proud ofNoXqcsMotosport has much to be proud ofNoXqcsMotosport has much to be proud ofNoXqcsMotosport has much to be proud ofNoXqcsMotosport has much to be proud ofNoXqcsMotosport has much to be proud ofNoXqcsMotosport has much to be proud of
^^^ that intake could eat small children, nice work
Old 01-26-2009, 01:53 PM #52
VegasSE's Avatar
Quote:
haha. I think I've done EVERYTHING you can possibly do to a Supra in that car. With the exception of converting one to all wheel drive, I don't really know what else you could even do to the car to improve it. My bank account still hurts from building this car. haha
Old 01-27-2009, 10:42 PM #53
drektek's Avatar
drektek is on a distinguished road
Send a message via AIM to drektek
really nice cars. makes me want to buy a Supra. I'd just be worried about leaving it parked
"is enough really ever enough?"
Old 02-01-2009, 11:31 AM #54
Imports's Avatar
Imports is on a distinguished road
My 94 TT 6-spd supra that i just sold Friday. It was a sad day, but hopefully my spirits will be lifted as im looking to hopefully get into a Cayenne Turbo this next week.
Old 02-06-2009, 03:08 PM #55
Bigdane is on a distinguished road
Ex mkiv owner here, I miss smoking the tires down at 70 mph.
2008 King Ranch F250 Fabtech 6"
BFG AT 37's
MBRP exhaust
KMC Diesel 20"
2005 Ducatti 999
KTM XCW 450
Old 02-06-2009, 04:20 PM #56
Snacks has a spectacular aura aboutSnacks has a spectacular aura about
Quote:
Originally Posted by bluzlee View Post
97 widebody, sc300 with 2jz, s2k and nsx!
Your white supra is unbelievable.
Old 02-07-2009, 06:05 PM #57
bluzlee is on a distinguished road
is for sale!
yeah, i love the widebody supra! it is for sale!! you know anybody may be interested?
Old 02-08-2009, 03:34 AM #58
gr814u is on a distinguished road
Here is mine.
Old 02-08-2009, 11:27 AM #59
JGTLucre is on a distinguished road
Send a message via MSN to JGTLucre
Miss my old lexus lol sold it to my nephew ...
2009 Kawasaki ZX10R, 1991 Toyota MR2
2002 Yamaha R6, 1995 Lexus SC400 /2jz-gte
1995 Lexus LS400, 1995 Mitsubishi Eclipse GST
1990 Mitsubishi Eclipse GSX, 2008 Audi R8
Old 02-13-2009, 10:30 AM #60
cherplex's Avatar
cherplex is on a distinguished road
Hey everyone I finally joined this forum, I have the same screen name on supraforums, clublexus and couple other sites. Here are a few pics of my SC300. I went from NA to BPU 1J to APU 1J to currently BPU USDM 2JZGTE soon to be APU 2jzgte lol. Indecisive maybe. The pics with the gold wheels are from the 1j days and the vid is from the modifiedmotion photoshoot.
Video:
Reply
Tags
300, 550whp, fl, forum, green, nice, replace, sale, sc, sc300, speed, start, tri, turbo, white
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
User CP
Visit our Sponsors
6SpeedOnline.com
Advertising - Jobs - Privacy Policy - Terms of Service
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Copyright Internet Brands
