Go Back   6speedonline.com Forums > Japanese > Other Japanese Supercars
Other Japanese Supercars Toyota Supra, Honda NSX, Maxda RX-7, Lexus IS-F/LF-A etc.
Welcome to 6SpeedOnline.com!
Welcome to 6SpeedOnline.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join 6SpeedOnline.com today!
Reply
Thread Tools Rate Thread Display Modes
Old 05-05-2009, 01:56 PM #1
VegasSE's Avatar
VegasSE is a jewel in the roughVegasSE is a jewel in the roughVegasSE is a jewel in the rough
FINALLY FINISHED.....1300whp SUPRA
Engine:
Virtual Works 3.4 stroker
CP Flat Top Pistons
Carillo Rods (upgraded carr bolts)
Crower Balanced Billet Crank
Clevite bearings
Program Billet mains
Line honed block
Fully polished and ported Virtual Works race head
Competition Copper Alloy valve seats
Five angle valve job
Ferrea dual valve springs
Ferrea titanium valves +2mm
Ferrea titanium retainers
Ferrea valve keepers
Ferrea spring seats
Ferrea spring locaters
Ferrea valve guides
ARP L19 Head studs
HKS 280 Cams
Unorthodox Cam gears
Unorthodox Pulleys
BoostLogic crank pulley
BoostLogic Billet tensioner
Virtual Works Dual Rail 12 injector Intake Manifold
Accufab 95mm Polished Throttle body
Virtual Works 8 ½ Quart Aluminum Oil Pan
Virtual Works Modified Pickup for Deep Pan
Virtual Works Modified Oil Pump
Virtual Works Modified Water Pump
Toyota P/S pump (new)
Power Enterprises Kevlar Timing belt
Power Enterprises Kevlar Serpentine belt
Chromed Valve covers
Powerhouse Polished Spark Plug Cover
TTC Polished Brake Cap
TTC Polished ABS Relay Cover
Greddy Billet Oil Cap
Virtual Works Aluminum Fuse Box Cover
Virtual Works Breather with custom 1/1 Can
All Cosmetic Bolts Switched to Stainless Allen Bolts
Lines Converted to Braided
Polished + Black Fittings
Extensive Chroming
TRD motor mounts
High Output Chromed Alternator
New Engine Harness
Engine Bay entirely stripped, holes welded, brackets ground, painted + cleared
Aluminum Belly Pan
Turbo + Exhaust:
Virtual Works coated turbo header T6
Tial 44mm wastegate
GT47-88mm Dual Ball Bearing turbo (polished and coated) T6
Virtual Works anti-surge turbo insert
Custom SP (chromed) 6” cold air intake
K+N 6 Inch Race Filter
Virtual Works Modified water neck (to fit large frame turbo)
Virtual Works 4 inch stainless coated downpipe
Virtual Works 4 inch stainless coated midpipe
Sound Performance 4 inch stainless boost actuated exhaust cutout
HKS racing bov
HKS 4 inch Hiper Titanium Exhaust
Cooling:
PWR Brushed Aluminum radiator
Virtual Works Custom Brushed Aluminum Dual Fans (6000cfm)
Sound Performance 5 inch race Intercooler
Custom Virtual Works 4” polished intake piping
Virtual Works Polished Upper and Lower Intercooler Straps
TRD Thermostat
Virtual Works Upper radiator hard pipe chromed
Virtual Works Lower radiator hard pipe chromed
Virtual Works Upper radiator cooling plate chromed
Upper Radiator show plate chromed
Virtual Works custom 1/1 Aluminum Overflow can
Trans + Clutch:
New V160 6-Speed Transmission
Tilton Carbon Triple Disc clutch
Custom 1pc steel driveshaft (cnc’d ends)
Virtual Works Driveshaft Loop
TRD LSD
TRD Trans Mount
Virtual Works CnC’d Aluminum shifter bushings
C’s Short Throw Shifter
Strain gauge
Fuel System:
Weldon 2835 Fuel Pump
Weldon Fuel Pressure Regulator
Virtual Works Dual Fuel Rails w/12 1000cc Injectors
Bosch 1000 high impedance injectors
Custom AN Fuel Lines
Suspension:
Virtual Works custom rear suspension
Virtual Works mini tub
Virtual Works chromoly rear control arms
TRD Sway bars (Ceramic Coated Silver)
Cusco carbon rear strut bar
DoLuck Cross Bar
Tein Flex coilovers front (spun on lathe to remove green to show spun aluminum)
Koni coilovers w/Eibach springs rear
Tein EDFC controller
Titan Billet mount kit
Extended Rear Studs
Electrical:
Motec M800 Engine Management
All Motec Sensors and upgrades
HKS DLI Twin Power Ignition
Blitz turbo timer
AEM Boost Gauge
Defi Water Temp + Oil Pressure Gauges
AEM Serial Gauge
FJO Wideband gauge custom mounted
TRD 10K Tach
Optima Trunk relocated battery
Brakes:
Brembo 14 Inch Big Brake Kit Painted Lambo Verde
Slotted front + rear Brembo rotors
Goodrich Stainless brake lines
Wheels + Tires:
HRE 597R 18X10 front
HRE 597R 18X12.5 rear
Mickey Thompson ET Street Drag Radial (345/35/18)
BFG Gforce ZR front (265/35/18)
Interior:
TRD Black Steering Wheel
TTC Drilled Performance Pedals
10% Tinted Windows
New Carpet 33,000 miles
New Factory OEM mats
New Factory Black Leather seats
SP Rear Seat Delete
Exterior:
Genuine DoLuck Late Model Front Bumper
Genuine Bomex side skirts
Genuine TRD Hood
Genuine TRD Wing
Clear Signal Markers
Smoked Side Markers
Smoked Taillights
Smoked Third Brake Light
3M Clear Bra
Performance:
Tuned by Mike Angel of Factor-X
RWHP: 1307
RWTQ: 965
Here it is with the stock hood/carbon wing on. I'm not sure which wing/hood set up I'm going with for sure. Most likely put the genuine TRD hood/wing back on the car.
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on 6SpeedOnline!
Old 05-05-2009, 03:00 PM #2
torquey5 is on a distinguished road
That turbo is too small.
Let's see some vids!!!
Old 05-05-2009, 04:03 PM #3
telum01 is a splendid one to beholdtelum01 is a splendid one to beholdtelum01 is a splendid one to beholdtelum01 is a splendid one to beholdtelum01 is a splendid one to beholdtelum01 is a splendid one to beholdtelum01 is a splendid one to beholdtelum01 is a splendid one to behold
Send a message via AIM to telum01
awesome build! quick question, though... with the BOV in the front bumper, and the outlet facing the front, does that cause any problems when it vents while you're at high speeds? the air is going to be going forward into the air the car is pushing through. plus, there's nothing to keep things from going into the BOV's outlet and it's in a very exposed spot.
Old 05-05-2009, 04:06 PM #4
jbracefan1977 has a brilliant futurejbracefan1977 has a brilliant futurejbracefan1977 has a brilliant futurejbracefan1977 has a brilliant futurejbracefan1977 has a brilliant futurejbracefan1977 has a brilliant futurejbracefan1977 has a brilliant futurejbracefan1977 has a brilliant futurejbracefan1977 has a brilliant futurejbracefan1977 has a brilliant futurejbracefan1977 has a brilliant future
Quote:
the car cannot go faster than the air is exiting the bov Im no math guy or a speller but the amount of boost is far stronger than ambient airflow even at 250+
granted I made all that up
nasty terrific car
Old 05-05-2009, 04:12 PM #5
noekult's Avatar
noekult has much to be proud ofnoekult has much to be proud ofnoekult has much to be proud ofnoekult has much to be proud ofnoekult has much to be proud ofnoekult has much to be proud ofnoekult has much to be proud ofnoekult has much to be proud ofnoekult has much to be proud of
You nailed it... One of my favorite Supras...!
Old 05-05-2009, 04:20 PM #6
love how the intake piping is larger than my house
Old 05-05-2009, 04:30 PM #7
SXN SXN is offline
SXN is a name known to allSXN is a name known to allSXN is a name known to allSXN is a name known to allSXN is a name known to allSXN is a name known to all
Same post as on SF: Awesome build bro.
2002 911 Turbo
1996 Supra Turbo =(
1994 Supra Turbo
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
Old 05-05-2009, 07:55 PM #8
Fantasma is a splendid one to beholdFantasma is a splendid one to beholdFantasma is a splendid one to beholdFantasma is a splendid one to beholdFantasma is a splendid one to beholdFantasma is a splendid one to beholdFantasma is a splendid one to behold
i cant even begin to imagine the amount of lag you have on that
- 09 GTR - 505AWHP
- 09 Merc SL63 - gone
- 08 Cayenne GTS - gone
- 11 Others - gone
Old 05-05-2009, 08:13 PM #9
VegasSE's Avatar
Quote:
None when you spin it to 9000 and shift. You stay in the boost the whole time. It's really a highway car. Just pick the right gear that puts you in boost and away you go.
Old 05-06-2009, 02:58 AM #10
SupraRacer007's Avatar
SupraRacer007 will become famous soon enoughSupraRacer007 will become famous soon enough
Send a message via MSN to SupraRacer007
I'm very impressed! Beautiful car ... you have a serious amount of $$$ in that 3.4 stroker motor alone. The first 3.4 I saw & heard was Ken Henderson's car at the Vegas meet a couple years ago. I can't even imagine that kind of HP in my Supra ... crazy! I love the Virtual Works pieces ... very nice aluminum work.
Good luck ... great Supra you have
Stephen
Old 05-06-2009, 09:20 AM #11
got_hp?'s Avatar
got_hp? is on a distinguished road
wtf @ green brake calipers?
the engine bay is gorgeous......must be nice to be loaded!
93 RX7 Brilliant Black
My tombstone will read "I spent 90% of my money on women, cars, and booze. The other 10% I wasted.
Old 05-06-2009, 09:44 AM #12
RFFG's Avatar
RFFG will become famous soon enough
Stunning.
2009 SGM Lexus IS250
F-Sport Springs - Custom Intake
Notables: 1990 Turbo Mustang / 2008 Impreza STI / 1998 Impreza GF8 / 2004 Impreza STI / 2008 Lexus IS 250
Old 05-06-2009, 10:06 AM #13
SpeedLimit?'s Avatar
SpeedLimit? is on a distinguished road
What's the HP total for the garage now bro? I remember it being a ludicrous number before the build. Thanks for the cool thread.
Old 05-06-2009, 10:30 AM #14
SFdreamer's Avatar
SFdreamer is just really niceSFdreamer is just really niceSFdreamer is just really niceSFdreamer is just really nice
Send a message via AIM to SFdreamer Send a message via MSN to SFdreamer Send a message via Skype™ to SFdreamer
Perfect example of a supra there! I think every penny was well spent.
Old 05-06-2009, 10:44 AM #15
VegasSE's Avatar
VWR is the best in terms of cosmetics and attention to detail. EVERY cosmetic bolt in that car is a stainless allen head!
Matches the Verde Twin Turbo Gallardo it sit's next to in the garage.
Quote:
I buy and sell them too much to keep up. :lol: Depends on if I make a trade this week.
Quote:
Originally Posted by RFFG View Post
Stunning.
Quote:
Thank you.
Reply
Tags
1300whp, 3453518, 98, bra, bushings, clear, custom, hp, inch, kansas, mount, shifter, supra, tire, transmission, trd, waterneck, zr
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
User CP
Visit our Sponsors
6SpeedOnline.com
Advertising - Jobs - Privacy Policy - Terms of Service
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Copyright Internet Brands
