Go Back   6speedonline.com Forums > Japanese > Other Japanese Supercars
Other Japanese Supercars Toyota Supra, Honda NSX, Maxda RX-7, Lexus IS-F/LF-A etc.
Welcome to 6SpeedOnline.com!
Welcome to 6SpeedOnline.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join 6SpeedOnline.com today!
Reply
Thread Tools Rate Thread Display Modes
Old 06-23-2009, 10:28 AM #46
xchosun1x's Avatar
xchosun1x is a jewel in the roughxchosun1x is a jewel in the roughxchosun1x is a jewel in the roughxchosun1x is a jewel in the rough
Send a message via AIM to xchosun1x
nice set up!
super clean
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on 6SpeedOnline!
Old 07-06-2009, 11:33 PM #47
maozisky is on a distinguished road
nice ride,man,nice ride!
Old 07-09-2009, 02:19 PM #48
VegasSE's Avatar
VegasSE is a jewel in the roughVegasSE is a jewel in the roughVegasSE is a jewel in the rough
Quote:
Originally Posted by xchosun1x View Post
nice set up!
super clean
Quote:
Thank you gentlemen. I'll put up pics of my blue one shortly as well. Twins!
Old 08-08-2009, 02:40 PM #49
VegasSE's Avatar
New goodies going in next week.
Shepherd Racing Rear Differential
Cusco LSD
REM ISF Process Ring + Pinion
Buschur Racing Rear Moustache Bar
Buschur Racing Rear Billet Side Diff Mounts
AWD Motorsports Aluminum Driveshaft
Buschur Racing Driveshaft Loop
Drive Shaft Shop Level 5 Rear Axles
AMS Oil Cooler
Spal Oil Cooler Fan
Old 08-09-2009, 12:35 PM #50
Apex Aaron's Avatar
Apex Aaron is on a distinguished road
Good Looking Set up
Old 08-09-2009, 02:44 PM #51
VegasSE's Avatar
Here are some pics of the new Evo. Sorry for the terrible cell phone pics. I'll snap new ones this week when the car is 100% done, along with the full mod list, but you get the idea. Start to finish this one took us 6 weeks.
Old 08-09-2009, 05:55 PM #52
EvoForever has much to be proud ofEvoForever has much to be proud ofEvoForever has much to be proud ofEvoForever has much to be proud ofEvoForever has much to be proud ofEvoForever has much to be proud ofEvoForever has much to be proud ofEvoForever has much to be proud ofEvoForever has much to be proud ofEvoForever has much to be proud of
all I can say is WOW!!!! nice
Old 08-09-2009, 07:37 PM #53
VegasSE's Avatar
Quote:
Full mod list for the Blue Evo.
ENGINE:
Freshly Built 2.1
4G64 2.4L Block
Wiseco 4G64 Forged 9.0:1 Stroker Pistons
4G63 Lightened and High Speed Balanced Crank
GRP Billet Aluminum Rods
ARP Rod Bolts
Race Balance Shaft Eliminator Kit
Clevite 77 Main Bearings
Clevite 77 Rod Bearings
O-Ringed Block
ARP Main Studs
ATI Super Damper
Fully polished and ported race head
Competition Copper Alloy valve seats
Five angle valve job
Ferrea dual valve springs
Ferrea titanium valves +1mm
Ferrea titanium retainers
Ferrea valve keepers
Ferrea spring seats
Ferrea spring locaters
Ferrea valve guides
ARP L19 Head studs
Kelford 280 cams
Titek Carbon Fiber Cam Gear cover
Agency Power Polished Billet Aluminum Motor Mounts
Agency Power Polished Billet Aluminum Trans Mount
Greddy Chrome Billet Oil Cap
Weapon-R Aluminum Catch Can
818 Billet Power Steering Cap
Powdercoated Blue Valve Cover
Polished A/C System
Polished Aluminum Thermostat Housing
Engine Bay Painted Body Color
Every cosmetic bolt changed Stainless Allen Bolts
AMS Custom Made Short Runner VSR Race Intake Manifold
BBK Throttle Body
Battery relocation kit to trunk
TURBO/COOLING:
Precision 6262 Billet Wheel Dual Ball Bearing Turbo
Polished and Shaved Compressor Housing
Virtual Works Polished Stainless Steel O2 Housing
DEI Titanium Turbo Heat Shield
Full Race T3 Turbo Manifold Jet Hot Coated
Tial 44mm Wastegate
Tial Blow Off Valve
Fluidyne Aluminum Radiator
Blitz 1.3 bar cap
Extreme Turbo Systems Black Anodized 3 ½ inch Front Mount Intercooler
Polished Aluminum Intercooler Piping
Virtual Works IC Pipe Strapping
Virtual Works Aluminum 4 inch intake
K&N Air Filter
APR Carbon Fiber Cooling Plate
Mishimoto Race Thermostat
Weapon-R Coolant Tank
Virtual Works Racing Modified Breather Can
Virtual Works Racing Polished Upper Radiator Hard Pipe
Virtual Works Racing Polished Lower Radiator Hard Pipe
Spal 10inch Low Profile Electric Fan
FUEL:
Full Blown Double Pumper System
AMS Black Anodized Fuel Rail
Precision 1200cc Injectors
Custom-10 fuel lines
Aeromotive FPR
TRANS/CLUTCH:
Shepherd Racing Stage 2
New throwout bearing
New clutch fork, pin and return springs
New speedometer gear and sensor
New slave cylinder and line
REM ISF hub/sleeves and shifter rails
REM ISF gearset with rails and hub/ sleeves
Double synchro 5th gear option
Shepherd Racing Stage 3 Transfer Case
Quaife LSD front differential
8mm to 10mm bolt upgrade
New seals and o-rings
Reshimming
Neodymium magnet
REM ISF Process
New ring and pinion with bearings
Exedy Wasabi Triple Ceramic Clutch
Hyper Multi Plate
B+M Short Throw Shifter
AMS Billet Shifter Bushings
ARC Titanium Shift Knob
WHEELS/SUSPENSION/BRAKES:
Volk Racing RE30 Matte Black 18X9
Volk Black Duraluminum Lug Nuts
Volk Black Duraluminum Value Stems + Caps
Volk GT High Center Caps
Advan Neova AD07 265/35/18
Tein Monoflex Coilovers
Tein Upper Pillow Ball Mounts with Camber Adjustment
6 Piston Stoptech Front Big Brake Kit
GT Spec Front Strut Bar
Cusco Rear Strut Bar
Agency Power Front + Rear Sway Bars
ELECTRONICS:
AEM EMS
AEM 5 Bar Map Sensor
Defi Water Gauge
Defi Exhaust Gas Temp Gauge
Defi Oil Temp Gauge
AEM Wideband
AEM Boost Gauge
Sparktech Coil On Plug Ignition System
Titec Carbon Fiber Fuse Box cover
Trunk Relocated Battery
Alpine Head Unit
Alpine Tweeters
Alpine Mids
EXTERIOR:
Chargespeed Type 1 Front Bumper
Carbon Fiber Front Bumper Diamond
Chargespeed Type 1 Side Skirts
Chargespeed Type 1 Rear Bumper
Chargespeed Vortex Generator
Seibon Carbon Fiber TSII Hood
Carbon Fiber Evo 8 Trunk Badging
Carbon Fiber Rear Diamond Badge
Rexpeed Carbon Fiber Mirror Covers
Rexpeed Carbon Fiber J-Panels
Varis Carbon Fiber Exterior B-Panels
Rexpeed Carbon Fiber Antenna
Hyboost Performance Edged + Tinted headlights
Hyboost Performance Tinted taillights
Hyboost Performance Smoked Side Markers
Freshly Painted BBY
INTERIOR:
Evo SE Suede/Leather Front and Rear Seats
Rexpeed Carbon Fiber Dash Kit
Carbon Fiber Console Shifter plate
Tyrant Carbon Fiber Armrest
Brand New OEM Mats
Old 08-10-2009, 12:29 PM #54
PathosRx is an unknown quantity at this point
Car looks good!
Old 08-12-2009, 09:39 PM #55
VegasSE's Avatar
Quote:
Originally Posted by PathosRx View Post
Car looks good!
Thanks. Both should be getting shot for a major magazine soon.
Old 08-17-2009, 06:40 PM #56
MorePSiTehBett4 is infamous around these partsMorePSiTehBett4 is infamous around these parts
why another one dude?(that's cool, just asking) Looks like the second one's going to rev really nice!
Are you going to take one of them to the drag strip?
01' BMW K1200RS Blue/Silver
04' STi Java Black Pearl(stage 2+) 350whp on vp109-Sold
03' WRX World Rally Blue(Bolt on's)-Sold
90'Camry Daily Beater Red
Old 08-19-2009, 10:57 AM #57
VegasSE's Avatar
Second one is going to my house in Tahoe to drive when I'm up there. As for your question, any track will kick them off after one run....street cars....no cages.
Old 08-19-2009, 11:59 AM #58
Chico@Vivid's Avatar
Platinum Sponsor
Chico@Vivid is a name known to allChico@Vivid is a name known to allChico@Vivid is a name known to allChico@Vivid is a name known to allChico@Vivid is a name known to allChico@Vivid is a name known to all
Awesome job on the EVO. The engine bay is super clean.
Jon
Old 08-20-2009, 03:24 PM #59
VegasSE's Avatar
Quote:
Jon
Thanks. The Blue one hits the dyno again today. I'm thinking close to 800awhp....we shall see.
Old 08-20-2009, 04:18 PM #60
AWD's Avatar
AWD AWD is offline
AWD is a splendid one to beholdAWD is a splendid one to beholdAWD is a splendid one to beholdAWD is a splendid one to beholdAWD is a splendid one to beholdAWD is a splendid one to beholdAWD is a splendid one to beholdAWD is a splendid one to behold
Thumbs up
You sir are a true enthusiast!!
Well done on all your cars....the Evo twins are truly awesome.
Upcoming projects....Under Construction!
Reply
Tags
2005, carbon, case, conversion, covers, din, double, evo, fiber, mirror, mitsubishi, racing, rexspeed, shep, stage, transfer, virtual, works
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
User CP
Visit our Sponsors
6SpeedOnline.com
Advertising - Jobs - Privacy Policy - Terms of Service
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Copyright Internet Brands
