Rotora Street Challenge Brake Kit for Acura NSX
Rotora Street Challenge:
Rotora's high-performance Street Challenge Brake System enables superior brake modulation while improving overall pedal feel to ensure equal distribution of weight transfer when braking.To achieve this proportional front-to-rear brake bias, Rotora’s brake systems are strategically engineered to work in conjunction with the original vehicle stock master cylinder thereby producing shorter stopping distances.In using larger calipers and discs made with stronger, lighter weight material, Rotora Brake System’s thermal capacity and brake torque is increased over the vehicles original brake system.These are the design enhancements that are demanded in high-performance street and track vehicles.All Rotora Brake Systems are fully compatible with ABS and traction control systems.All brake components are direct bolt-on systems for production vehicles with minimal modifications required.
Brake Specs:
F: Forged 6-Piston Red Calipers / 355x32mm 2-Piece Slotted Discs
R: Forged 4-Piston Red Calipers / 328x28mm 2-Piece Slotted Discs
Contact Ben for pricing and information
Email: benson@rotora.com
TEL: 626.813.7900 ext. 100
STREET CHALLENGE STANDARD COMPONENTS: (PER AXLE)
A SET OF FORGED ALUMINUM, LIGHTWEIGHT CALIPERS: WITH DUST BOOT SEALS
A SET OF 1-PIECE OR 2-PIECE DIRECTIONAL DISC RINGS: HEAT-TREATED, ZINC PLATED (SLOTTED OR DRILLED/SLOTTED)
FOR 2-PIECE DISC SYSTEM: A SET OF FORGED ALUMINUM HATS (6061-T6, BLACK ANODIZE FINISH) WITH ANTI-RATTLE FLOAT DRIVE HARDWARE
A SET OF ALUMINUM (7075-T6) OR CARBON STEEL (S45C) CALIPER BRACKETS, WITH HARDWARE (DEPENDING ON APPLICATION)
A SET OF STAINLESS STEEL BRAIDED BRAKE LINES (DOT COMPLIANT), WITH HARDWARE
A SET OF H2 CERAMIC STREET PADS (NOT SUITABLE FOR FULL TRACK USE)
OPTIONAL: HIGHER STREET TO RACE PAD COMPOUNDS ARE AVAILABLE (PLEASE CALL ROTORA FOR FURTHER ASSISTANCE IN PAD GRADE SELECTION)
Brake Specs:
ECS Tuning - VW
08-20-2015 03:07 PM
PelicanParts.com
930 Turbo Vendor Classifieds
08-18-2015 04:01 PM
PelicanParts.com
993 Vendor Classifieds
08-18-2015 03:55 PM
