Other Japanese Supercars Toyota Supra, Honda NSX, Mazda RX-7 etc.
Titan Motorsports ARP 2000 2JZ Crank Bolt Kit
Old 07-27-2016, 02:31 PM
titannero's Avatar
titannero is just really nicetitannero is just really nicetitannero is just really nicetitannero is just really nicetitannero is just really nice
Titan Motorsports has partnered with industry leading fastener manufacturer ARP to develop an upgraded crank bolt kit for the Toyota 2JZ engine. These upgraded units are manufactured using ARP 2000 material which offers a tensile strength of 220,000 PSI, over 45% stronger than the factory specified Grade 8 bolt. This increase in material strength is partnered with an oversized washer which is both thicker and larger in diameter to take advantage of the increased clamping load and to properly secure the damper to the crank over a larger surface area.
The additional clamp load delivered helps secure the harmonic damper to the crankshaft allowing it to function as designed, absorbing the unwanted kinetic energy caused by undesired movement of the crankshaft. This reduces the risk of the damper loosening from the crankshaft that can occur in racing environments where high RPMs are the norm. This bolt kit is designed to work with the OEM crank pulley, however we recommend it be paired with our Titan Motorsports Crank Damper to offer the ultimate in protection for your engine.
flatsixing
12-02-2023 12:47 AM
GCBC
07-18-2016 07:56 PM
Wheel Dynamics
03-30-2016 11:11 AM
Wheel Dynamics
03-30-2016 11:09 AM
Wheel Dynamics
Wheels/Tires
03-30-2016 10:40 AM
Quick Reply: Titan Motorsports ARP 2000 2JZ Crank Bolt Kit
