New Panamera Turbo Carbon Y-Pipe Kits are Here
Old 05-08-2013, 02:34 PM
vividracing's Avatar
We just got in our new carbon fiber Panamera Turbo y-pipes that are simply flawless. Must have, tons of performance gain. View more info and pics here - http://www.vividracing.com/catalog/s...-970tt-10.html
With the insane results of our aluminum Y-Pipe kit for the Porsche Panamera Turbo, we wanted to step up the luxury look of the engine bay with a full carbon fiber version. This carbon fiber Y-Pipe is a full replacement and includes everything you need to install in place of the original.
Looking at the stock Y design in front of the throttle body, we new there was improvements to be made. This throttle body is the same size as the Cayenne TT throttle body we use on our 996TT and 997TT upgrade kits. The stock Y-Pipe is a 2 piece plastic Y design that is smooth on the inside with a "deflector" internally to channel air. The bad part about the stock one is it goes from a 78mm ID at the throttle body down to a approximately 51mm diameter Y split. This then connects to rubber boost hoses that expand under pressure. Both of these are a power robbers! If you retain the stock design and stock diameter hoses, YOU CANNOT GAIN power no matter if the YPipe is cast aluminum or plastic. This is why we made a complete Y-Pipe kit which retains a 3inch diameter design all the way to the factory end piece connections at the intercoolers.
The dyno sheet shows the car in standard mode with the stock Y piece versus our big Y-Pipe kit. These are huge gains throughout the ENTIRE rpm band which is impressive. Dyno proven results are not something to see, but something you can feel. The more airflow you get into that throttlebody the more HP you will gain. By eliminating the rubber boost hoses, you remove the pressure fluctuation from expansion which loses power. With our Y-Pipe kit, the air flow improvement improves every aspect of driving your Panamera Turbo. As tested on our Mustang AWD Dyno, the Y-Pipe made 34awhp and 35ft/lbs of torque.
These Y-Pipes are all made in the USA using carbon fiber braided sleeve and a bladder molding technique. The Y-Pipe includes necessary couplers and clamps for a true bolt on installation. All clamps should be torqued to no more then 15lbs. These are designed for the 2010 and up Porsche Panamera Turbo.
We also have some pipes on clearance. These have small blems or weave issues. Buy here - http://www.vividracing.com/catalog/s...-970tt-10.html
Old 04-03-2014, 10:22 AM
Pipes instock! Most power and improvement on the Panni Turbo you can get for a bolt on!
ID:	354917   Click image for larger version
ID:	354918   Click image for larger version
Old 08-19-2014, 10:00 PM
Chris_FL's Avatar
Chris_FL is a jewel in the roughChris_FL is a jewel in the roughChris_FL is a jewel in the rough
Is there a similar product for the GTS?
Old 08-20-2014, 12:22 PM
2010Panny4S's Avatar
2010Panny4S will become famous soon enough
Looks sweet.
Old 11-19-2014, 03:32 PM
MIA997TTBeast's Avatar
MIA997TTBeast will become famous soon enoughMIA997TTBeast will become famous soon enough
Could you PM me price? Thanks.
Old 11-20-2014, 09:19 AM
s4orce666's Avatar
s4orce666 is on a distinguished road
Please PM me for pricing as well. Thanks!
Old 11-20-2014, 11:34 AM
Pm sent
08-21-2015 06:34 AM
PelicanParts.com
Panamera Vendor Classifieds
08-20-2015 02:50 PM
Quick Reply: New Panamera Turbo Carbon Y-Pipe Kits are Here
