Porsche Universal Charger (AC) details
#49
How come you never used it? What causes people to buy such expensive chargers and not have a need for them?
#50
I didn't buy the charger it came with the car. I actually use the charger portion when I park at the airport etc where there are outlets. At home I have a smaller wall unit that I charge with for my daily juice. I just think the Porsche docking cabinet is too big and bulky. The unit I installed was free after a rebate from my utility company.
#51
Really, the Porsche unit is huge. Your pictured unit is probably less than half the size. The Turbocord I bought for use on trips (and have barely used, kinda silly of me) packs the same electronics into a box that's maybe 4" x 4".
#53
It appears impossible at this time to send you private messages, MacsterHybrid. I'm guessing you haven't enabled it in your profile or something.
You've got two posts, and the other is an inquiry about shipping a Cayenne Hybrid. That should come with a charging dock.
If you still need one, I recently sold my Panamera S e Hybrid, and the dock went with it, but I still have the Turbocord I purchased for traveling. It's a 110 / 220 EVSE, like the Porsche unit, but a lot more compact. I've been meaning to put it up on eBay.
#54
#55
Aha. Therin lies a story. Prepared to be bored.
I looked at a variety of cars - a Panamera GTS, a Panamera Turbo, a BMW i8, and a Jaguar F type R AWD. I was dead set against getting another Porsche coupe, since we already owned a Cayman S. I figured the overlap between the two cars would be too great.
I was sure that I'd prefer the i8 over everything else. Another hybrid, with the things I found attractive about a plug-in hybrid, but in a much sportier chassis. I was underwhelmed by the actual test drive. The carbon-fiber tub makes for an incredibly awkward door frame, tall and thick. It was the first time I'd actually had problems getting into and out of a car. Rear visibility was poor, and performance not nearly what I thought it would be. It was an OK car, but not much of an improvement overall, particularly for the money.
The Panamera GTS felt pretty much like the S e Hybrid. The low end torque was about the same, despite the much larger NA engine. I only felt a difference above about 5000 RPM, which isn't someplace I go routinely. The Turbo was definitely faster, but I was still aware of how big and awkward the car was.
The Jaguar F type had plenty of grunt, but rear visibility was poor, the trunk very cramped, and overall the driving experience was kind of crude.
On a whim, despite my earlier resolution, I test drove a 2012 991.1 S immediately after driving the F type. It was night and day better. It had far and away more rear visibility than anything I'd test driven, and the performance was better than the Panamera Turbo.
After shopping around, I found an 2014 991.1 4S Cabriolet in Amaranth Red. We paid too much for it, because all the other local cars were gray, white, or black, and getting a color I wanted would otherwise mean going out of state.
I felt rather bad about trading in the Panamera. Since I ordered it, it was a car literally built to my specifications, for me personally. I owned my prior car for 16 years, and I gave up on this one after just 2. Every time I drive the 911, though, it reminds me of how much more enjoyable it is to drive. Just parking it alone is a huge difference, since the size makes it so much more nimble and easier for me to estimate distances.
#56
Advice?
I purchased used 2014 Panamera S e hybrid and it didn't come with charging cable. I've won car on auction for a great price so I didn't make a big deal about it.
I'll be shipping car to Czech Republic in 8 months but for now I'd like the least expensive cable just to charge my vehicle overnight.
I'd like to use regular 110v outlet to charge it don't mind longer charging time because it will be done overnight anyway and after I ship the car I'll have no use for the charger unless I can change the cable for Europe version.
Thank you guys!
Thank you guys!
#57
There's a level 1 (110v, 15 amp) available on Amazon for $300. You may also consider one of the EVSE's that can handle either 110 or 220, which would be usable in the Czech republic with a suitable plug adapter.
RE: Czech outlets, I couldn't quickly find any information about high-current outlets. While the standard outlet is apparently a type E 220v/16 amps, and that's barely within tolerances for a level-2 EVSE feeding the 3.6 kW charger in the PSeH, I'd want to talk to an electrician before trying that. In North America we have a variety of 220 volt socket standards, depending on maximum draw from 15 amps to 60. I'd assume there are 20+ amp socket standards the Czech Republic.
I've been meaning to get rid of my AV Turbocord which will handle both 110 and 220, so that's a possibility, but I wouldn't want you to feel like I was trying to sell that to you.
#58
Thank you guys!
Thank you guys!
#59
Robotpedlr - I hope all is well. I am a new panamera e-hybrid owner (purchased certified pre-owned) and the universal charger didn't come with a manual. Upon plugging it into a 240V outlet, it asked me to select the "current" at either 50 or 100%. I selected 100% and it seemed to charge just fine. However, I was wondering if your manual has anything about it in there and discusses reasons/pros/cons for setting it at either setting. Any help you could provide would be greatly appreciated. Thanks!
#60
