Help - 997 Coolant tank removal
Many thanks for any advice to get this tank out and replaced.
I have lowered engine, removed connecting hoses necessary and still having problems. On of the repair documents I have stated remove the wiring harness that runs along side the engine and then also unclamp fuel pipe in order to manuever old pump out and new in but not sure how to do this.
I have unplugged coil and sensor plugs that will allow some wiring harness movement. Is this all that is needed and I just need to keep fighting it ?
Stuck with car on stands, engine down and old tank not budging
04-28-2022 12:38 AM
