2003 X-50 SRM Build. 767 whp Pump, 850 E-85
Just wanted to share the exciting results from my recent build with Sean at SRM.
I purchased the car about 4 years ago and have been slowly modding it throughout the years but knew the limits of the rods so never wanted to push it too hard.
I reached out to Sean and told him my budget and what I wanted and he said he could make it happen. I dropped off the car July 8th and picked it up the previous weekend.
Here is what was down.
SRM Rods
12 mm head studs- ARP studs he uses
Factory head gasket
1300 Bosch injectors
SRM complete fuel system. Dual 450 pumps, rails etc.
SRM 4.5" intercoolers
SRM Y Pipe
SRM Plenum
SRM Billet Flywheel, Tilton Cermetallic triple plate
K & N Filters directly on turbos
Cobb tuning by Brandon at I believe Brenspeed
Previous parts that remain on the car
K24/20g Stage 2 Turbos from Mark at 911tuning
Old Speed Technologies exhaust
The car is an absolute blast to drive, tons of power, idles great and the clutch is very easy to use with nice pedal pressure.
I can't say enough about how happy I am with how everything worked out!!
Thank you SRM!!!!
SRM Rods
Factory head gasket
SRM Y Pipe
SRM Plenum
Thank you SRM!!!!
Congrats on your build. Just a few questions.
Did I read it right that it took about 5 months to do the build? This is the drop in rods with no machine work right?
What are the SRM rods and Tilton Clutch rated for in Torque?
Did you have it put on a dyno? Always fun to see graphs even though PBOX and Track times really tell the story.
I bet it is great fun to drive!
Thanks for the info.
Great numbers!
I'm really tempted to drop my car off for the full SRM treatment with pretty much the same parts, but I'd really miss the car if it was gone for half a year! Makes a winter build more appealing for sure.
How much boost on pump and E85?
What kind of dyno? Can you share the graphs?
Enjoy the car! I'm sure it's a blast.
Nice #'s. I originally read that as a one week turn around, but almost 6 months!!!, No way I would be okay with that.
Great numbers!
91 octane was 24 lbs of boost.
27 lbs on e-85.
To me It was worth the wait knowing I took it to the right shop where it would get built right
Heres what doesnt make sense.
The link shows another guy runs 25psi of boost on 91 octane and makes 725rwhp not awhp.
https://www.6speedonline.com/forums/...2471-cobb.html
But the OP runs less boost on 91 octane and makes 767awhp?????
The dyno chart is showing 120hp loss after 5500rpm timing is being pulled.
Looking at the curve, if the goal is a fast/fun street car, I bet the OP is happy.
